Chat Area => General Discussion Area => Topic started by: Gaffers on 25 March 2008, 16:47:40
Title: One for those of you in the Ol' Bill
Post by: Gaffers on 25 March 2008, 16:47:40
What is the largest size adn weight of a boat I can legally tow with my omega?
I am investigating 3 boats I would like to build at some point and one of them has a beam (width) of 2.82m or 9'3".  Not sure exactly what the weight is but it is more than 2500Lb or 1136kg.
Will I have to get a bigger car if I want to trailor this mama?  :(
Title: Re: One for those of you in the Ol' Bill
Post by: hotel21 on 25 March 2008, 17:16:27
Check the label on the drivers B pillar.  It will show the max permissable weights for the front and rear axles as well as a larger figure which is the train weight.  Thats the all up weight of the car, its fuel and contents, as well as the trailer being towed and whatever is upon the trailer.
The lighter the trailer, the heavier the potential boat....
Post by: Kevin Wood on 25 March 2008, 17:21:52
Not in the old bill but I'll have a crack...
Depends how heavy the trailer is. You'll need a braked trailer for that sort of weight and the maximum towing weight of an Omega will be in the region of 1.7 - 1.8 Tonnes, so if the trailer isn't too heavy tou will be OK.
IIRC, the plate on the driver's door pillar will have two weights - the maximum laden weight of the vehicle and the maximum train weight. One should be around 2200 Kg and one around 4000. If you subtract the larger from the smaller this is the worst case maximum load you can tow with a fully laden car.*
Best practice is to tow only around 85% of the car's kerb weight but if you're careful, sticking to fairly short journeys and thus remaining alert  this can be exceeded. I have towed 1800 kg with mine and it was perfectly well behaved. Even managed to extract the trailer from a muddy field with the TC going nuts.
* - Assuming you've got an older license with a B+E entitlement.
Post by: Gaffers on 25 March 2008, 17:31:39
Thanks, I do have grandad rights...just!!   ;D ;D ;D ;D
I think I will just be in limits then for the weight, what about the beam (width) and the length limits I'm sure there is a maximum somewhere.  :-/
I probably wouldent trailor it everywhere but mainly to take it home over winter for maintenance and occasionally taking it somewhere new for exploration.
Post by: Martin_1962 on 25 March 2008, 17:33:53
2.3 m is the legal maximum with a car, hence all UK caravans being of this size or under. Rules are different for light comercials (over 3.5T).
EU Vans can be wider but are not legal with UK tow cars despite being legal in Europe
Post by: hotel21 on 25 March 2008, 17:35:48
theres also this to look at....
http://www.direct.gov.uk/en/Motoring/DriverLicensing/CaravansTrailersCommercialVehicles/DG_10013073
Post by: Kevin Wood on 25 March 2008, 17:39:18
Not aware of any width or length limits within reason. Obviously ensure you have enough lighting if bits of the trailer protrude or if it is long ensure it has some repeaters down the side.
I tow a glider trailer that's probably 9 or 10m long. You need to watch the speed doesn't creep up down hills because it will snake a little, especially if upset by a passing lorry, etc. Keep the speed down to 55 or less (just set the cruise) and it's fine though.
Having said that, fitting a stabilising device to the hitch is supposed to be worthwhile. Haven't tried one myself as I very rarely tow it.
Post by: Kevin Wood on 25 March 2008, 17:42:30
Here we go. Construction and use requirements for trailers:
http://www.dft.gov.uk/pgr/roads/vehicles/vssafety/requirementsfortrailers
Post by: Kevin Wood on 25 March 2008, 17:47:52
Looks like my glider trailer falls foul of the 7 metre length limit.  :o
Wing span is 15 metres, wing is in 2 sections so it's going to be more than 7.5 metres. I doubt there's a glider trailer that is compliant with that.
Post by: hotel21 on 25 March 2008, 17:48:25
Looks like your glider trailer is a tad overlength then, Kevin....     :-X   ;D
Post by: Kevin Wood on 25 March 2008, 17:59:50
I see 3 Options:
Sell the Omega and get a vehicle over 3.5 Tonnes  >:(
Take a saw to my glider  :'(
Plead ignorance during the 1 or 2 times a year I tow it  :-X
Post by: CaptainZok on 25 March 2008, 18:01:37
I see 3 Options:
Option 4, Carry an elastic tape measure. ;D
Post by: Gaffers on 25 March 2008, 18:05:10
Looks like the boat will too with a trailer being in the region of about 9m.....  :(
James, how much for your landy/range rover thingy??   ;D ;D ;D ;D
Post by: Martin_1962 on 25 March 2008, 18:07:51
I think they are too small too
Laxer in Europe
Post by: Gaffers on 25 March 2008, 18:18:27
Laxer in Europe
True but I wont spend my entire career in Europe and as I am British forces I have to still stick to British vehicle regulations.   :(
Post by: Martin_1962 on 25 March 2008, 19:19:34
Laxer in Europe
Do you have a V or a circle on the front - that is the decider
Post by: Gaffers on 25 March 2008, 19:26:32
Laxer in Europe
sorry mate on the front of what?
Post by: Martin_1962 on 25 March 2008, 19:30:33
Laxer in Europe
Car - Opel - German reg no problems with width
Post by: Gaffers on 25 March 2008, 19:51:19
oops sorry blonde moment there.....
nope defo a V..... :(
Post by: Martin_1962 on 25 March 2008, 21:18:45
To be honest if it isn't too much out of size I'd risk it - where are the traffic Police these days. I think if you were seen you would be OK
Post by: Kevin Wood on 25 March 2008, 21:28:14
As I said, almost every glider trailer will be over length. I belong to a gliding club where there must be at least 200 such trailers based. Some are used regularly on the road and I've never known anyone to have anything more substantial than a normal car as a towing vehicle.
I am not aware of anyone who has been pulled up on this, and that includes a few who have had the misfortune to have accidents on the road, where if anyone were likely to uncover the issue an insurance company would.
Post by: hotel21 on 26 March 2008, 09:29:33
Portmoak, the Scottish Gliding Centre, is right on the edge of my area and we regularly see glider trailers being hauled up and down the County.  The length of such things do not figure high on the agenda, to be honest.....   :y
