Omega Help Area => Omega Electrical and Audio Help => Topic started by: Field Marshal Dr. Opti on 21 February 2012, 13:01:14
Title: Central locking problem.
Post by: Field Marshal Dr. Opti on 21 February 2012, 13:01:14
The front passenger door refuses to lock and unlock. The other three doors are fine.
 Any ideas please?
Title: Re: Central locking problem.
Post by: Kevin Wood on 21 February 2012, 13:08:28
Likely to be the little microswitch in the central locking motor.
Either change the motor as per the maintenance guide or strip the motor down and change the switch (much cheaper). While the lock mechanism is out of the car it's worthwhile giving it a good clean and lubricate.
Post by: tunnie on 21 February 2012, 13:39:04
http://www.omegaowners.com/forum/index.php?topic=90543.0 (http://www.omegaowners.com/forum/index.php?topic=90543.0)
Post by: Field Marshal Dr. Opti on 21 February 2012, 18:00:50
Thanks Kevin and Tunnie. I have the tools so I'll give it a go... :y :y
Post by: carpediem82 on 23 February 2012, 20:50:14
I had a similar problem on my earlier Astra. After you reach the microswtich, test if he is receiving power. On mine was a wire broken, the switch was ok.
