Omega Help Area => Omega Electrical and Audio Help => Topic started by: tunnie on 27 February 2012, 09:48:52
Is there an option to save your current position to the address book? I had problems locating an address :-\
I went through the menu, but could not find anything :-\
It was in Tolworth, which according to the Omega Sat Nav does not exist ::)
I tried finding the road under Kingston Upon Thames, but it did not list it. :(
Had more frustrations trying to input "Acton" but after much swearing I found it was listed under London. Is there a rule as to what areas of London are listed as London?
Its fine out in the country, but appears to struggle in the London regions.
It was a 2004 disc, but Tolworth was about then ::)
Perhaps it supports wishful thinking? ;D
Unfortunately not... I find London addresses can be frustrating too. I think a 2004 disc should be able to cope with partial postcodes though :-\
try surbiton???
( i used to live just of ditton road for a while)
will try that next time in the car :y
You're welcome to have my 2008 (I think, might have been 2009/10) disk on extended loan swapsies for yours if the newer disk is better - I never did get round to fixing the aerial on mine anyway ;D
I belive it uses data from RM, so would be the official Post Town.
ahh that explains alot bloody RM >:(
is it true that you can input a partial postcode ? if so does this go into town?? i have the 2008/2009 disc
Didn't think the Siemens unit could do 5 digit postcodes. The CARiN units can, if running latest firmware.
You're more likely to be right than me :-[ :-[ I haven't even started mine for about 8 weeks, never mind looked at the sat nav ::)
No post codes on ncdc, sadly.
