Omega Help Area => Omega Electrical and Audio Help => Topic started by: Drewomega on 27 February 2012, 13:41:53
Title: Coolant level warning!
Post by: Drewomega on 27 February 2012, 13:41:53
Hi All OOFers!
My coolant level warning came on yesterday when on a dual carriageway. I stopped and had a look at level in header tank. All was ok. When I got home I checked the plug underneath the header tank and also the float inside. Everything seemed normal. Is this a normal complaint on the Omega? I have looked at other posts on here and I cannot see any answers to my question or even a fix. Thanks!!
Title: Re: Coolant level warning!
Post by: RobG on 27 February 2012, 13:44:01
Hi All OOFers!
Common fault. Replace tank
Post by: fiend61 on 27 February 2012, 14:04:28
try pushing float up and down a few times in tank they can sometimes stick  :y
oh make sure it has cooled down first though  :D
Post by: Drewomega on 27 February 2012, 15:14:37
oh make sure it has cooled down first though ;D ;D
Seem to have fixed it! I took the clip off which attaches the tank to the chassis. I removed plug from bottom of tank and cleaned both plug and socket pins then sprayed with WD40.  :y
Post by: fiend61 on 27 February 2012, 15:35:50
nice easy fix then and saved yourself £30 ish  :y
no burnt finger  :y
but no new shiney tank  :(
well done  :y
Post by: Drewomega on 27 February 2012, 15:51:52
Thanks guys!!  :y :y
