Author Topic: weird happenings  (Read 2987 times)
nyckt
  • winchester hampshire
    • Omega 2.0 16v Cdx
weird happenings
« on: 28 February 2012, 09:57:02 »
I have a omege cdi and had the water pump and cam belt done, crank sensor was change for a non genuine part. >:(
air bag light and eml(engine with spanner) light came on and stays on, rev counter and speedo drop and engine stutters, also the air con flickers and blows mad only last a split second then back to normal. warning light still on.
went back and had gen crank sensor fitted also a new alternator as supected that was the fault, (low voltage).
but to no availe still playing up and vauxhall want 400 quid to try to diagnose the fault.
anyone have an idea as to what the ********** is happening?
Re: weird happenings
« Reply #1 on: 28 February 2012, 10:03:50 »
Contact Kevin Wood by sending a personal message.He lives in Hampshire,and can do a proper diagnosis for a hell of a lot less than that. :y
« Last Edit: 28 February 2012, 10:13:16 by Albs »
« Reply #2 on: 28 February 2012, 10:06:11 »
Yep, happy to help and not far away from you.
First thing you can do, though is to try the paper clip / pedal test and see what codes the engine ECU is reporting.
http://www.omegaowners.com/forum/index.php?topic=90581.0
Pattern crank sensors normally don't work to well, in our experience.
« Reply #3 on: 28 February 2012, 10:14:00 »
And he appears right on cue,as if by magic. :y ;D
tango
  • brum
« Reply #4 on: 28 February 2012, 10:17:25 »
maybe sound silly and obvious but have you checked all wiring connections are snug tight and in their proper places
nyckt
    • Omega 2.0 16v Cdx
« Reply #5 on: 28 February 2012, 12:32:32 »
i have checked and rechecked all connections and all snug as i can see. kevin can you email me so i can get your expert eyes to look see ( creep creep) am in winchester (nr tescos)
nyckt
    • Omega 2.0 16v Cdx
« Reply #6 on: 29 February 2012, 08:11:50 »
tried the paperclip test, with and without pedals and had no response from the lights at all???
nyckt
    • Omega 2.0 16v Cdx
« Reply #7 on: 01 March 2012, 10:09:39 »
Kevin has been in touch and will be on the case shortly  ;D thanks.
