Pages: 1 2 [3]  All   Go Down
Author Topic: The Grand Oil Cooler Project  (Read 9943 times)
Re: The Grand Oil Cooler Project
« Reply #30 on: 15 March 2012, 17:12:26 »
Keep an eye on your hoses amd HBV for a while.Its not uncommon for them to fail after being soaked in oil from the inside. ;)
Colin G
  • West Bridgford, Nottingham
  • I'm a patient man...........usually
    • Omega 2.2 Sport
« Reply #31 on: 15 March 2012, 17:23:02 »
Cheers Albs, will do, changed the HBV while I had it all stripped down.
Colin G
    • Omega 2.2 Sport
« Reply #32 on: 16 March 2012, 12:26:50 »
Fianal update. just got back from MOT and it passed with NO advisories - think that is the first time ever!!!
Colin G
    • Omega 2.2 Sport
« Reply #33 on: 18 March 2012, 11:43:06 »
Sorry to resurrect this, I've done about 100miles and everything appears fine however, I've just checked the levels which are all fine but I noticed that there was some oil in the coolant tank, no mayo.  Now the oil on the dipstick is nice and clean as I did an oil change when I put it all back together. The small amount of oil in the coolant tank is as black as your hat, the same colour as the old oil I drained out of the sump.  My question is and I hope the answer is what I think it is, is it likely just to be residual oil from the oil cooler failure?  I did loads of flushing but I did notice some small globs of mayo when I did the final fill with antifreeze and decided I'd give it a couple of weeks of running and then drain down and flush again to finally clear them out.  I notice that there aren't any floating in the coolant tank at the moment.
I shall run for a few more days and see what's what.
Cheers Col
« Reply #34 on: 18 March 2012, 13:28:29 »
I had the same thing a month or so ago.I thought I might have still had a leak,but quite a lot more flushing cleared it and all was well. :y
Colin G
    • Omega 2.2 Sport
« Reply #35 on: 19 March 2012, 18:28:02 »
Thanks albs, I thought it must be residual due to the colour fingers crossed when I delve further.
Pages: 1 2 [3]  All   Go Up
