Author Topic: Pumping out water ? Help !  (Read 4129 times)
Re: Pumping out water ? Help !
« Reply #15 on: 01 March 2012, 19:27:27 »
Just re read that old post and noticed you had read it yourself  ::)
As MarkDTM and Daz said, give it a try, it worked for me  :y
Leave the fernox in there for a couple of days or longer if you can.
hth  :y
Does the rad have to come off ? Just thinking about blocking the pipes off if i can , then filling it with the rad flush  :-\ then again i wont be able to reverse flush it  ::)
Yes, pull it out and lay it flat on the ground in you back garden.
I blocked up the holes with a few poly bags and some gaffa tape.
As mentioned before, leave the fernox or similar stuff (I got mine from B&Q) as long as you can  :y
Ok thanks for your help TG  ;) Looks like a weekend job as cant take off the road till then ....will give it a try  :y
Failing that it will be water pump next  ::)
Thanks all  ;)
« Last Edit: 01 March 2012, 19:30:28 by eatmydust »
« Reply #16 on: 01 March 2012, 21:31:00 »
Cant remember who quoted this but could this be why my rad is not being as eficient as it should be .
SLudgepump = autogearbox
box to air is gearbox heat exchanged in radiator to cool it
I.E gearbox cooler built into side of rad thus making the rad do more work
Oil cooler in rad blocked , hence the faster the box works the hotter the rad will get from all the sludge . Internal auto box cooler blocked inside the rad  :-\
« Last Edit: 01 March 2012, 21:40:58 by eatmydust »
« Reply #17 on: 01 March 2012, 21:41:24 »
Unlikely - refers to small "oil cooler" for autobox built into drivers side of radiator.
« Reply #18 on: 01 March 2012, 21:42:33 »
The side of the radiator is where most autoboxes have their ATF cooler fitted as standard.  ;)
« Last Edit: 01 March 2012, 21:47:43 by Andy B »
« Reply #19 on: 01 March 2012, 21:45:58 »
When its off the car i will check the flow to the AT fluid cooler .... ;)
Gearbox works fine , would of been issues with the box me thinks if it was over heating the ATF  :-\
« Reply #20 on: 01 March 2012, 21:49:31 »
You're barking up the wrong radiator tree  ;)
« Reply #21 on: 01 March 2012, 21:53:01 »
Dam it  ::)  It was worth a try  ;)
See how much gunk i can get out if any from the rad at the weekend  ::) ::) ::) ::) ::) ::)
« Reply #22 on: 01 March 2012, 23:26:19 »
Don't try and "flush" the gearbox atf cooler mate - just the main radiator ;)
« Reply #23 on: 01 March 2012, 23:36:22 »
Ok  ;) Have sent you PM ....ill just flush the main rad  :y
« Reply #24 on: 02 March 2012, 00:14:05 »
And make sure you dont get any water or foreign objects in the autobox cooler while cleaning out the water rad. ;)
« Reply #25 on: 02 March 2012, 05:36:40 »
Will do albs  ;)
Guess its a hit and hope job that the rad cleaner will do its job working its way through every fin , looking at all the advice it does add up to the fact that the flow is getting blocked and pumping back up through the header .
On with the job , ill be taking the rad off later once i can get the rad cleaner  ;)
« Last Edit: 02 March 2012, 05:47:09 by eatmydust »
