Author Topic: 2.5 td running rough at idle  (Read 2083 times)
Opel 2.5TD
« on: 03 March 2012, 19:29:21 »
I have a 2.5 td with 170000 on the clock . Just before Xmas it started running rough at idle. As soon as throttle is opened it runs fine. The problem can come and go intermittently. I have followed old thread advice and filled fuel filter with Diesel Magic twice. It has improved a little but not cured. Is it worth repeating the Diesel Magic treatment or could there be another solution?
Agemo
  • Cleethorpes
  • Insignia
Re: 2.5 td running rough at idle
« Reply #1 on: 03 March 2012, 21:39:20 »
Always worth another go with Diesel Magic. Also, have the Leak-off pipes been replaced?
symes
  • oxford
    • R reg 940 volvo
« Reply #2 on: 03 March 2012, 22:16:25 »
dont know much about diesels but maybe split vacuum pipe somewhere ??
Opel 2.5TD
« Reply #3 on: 04 March 2012, 11:53:12 »
Thanks for advice
The leak off pipes have been replaced a couple of times, not leaking now as far as I know.
Opel 2.5TD
« Reply #4 on: 28 March 2012, 10:03:24 »
In case anyone else gets this problem, it has cleared now without repeating diesel magic trick but after using a few more tanks of regular non supermarket diesel. This is despite a diesel "expert" saying I would need a new pump at far more than the car is worth. So it looks likely that it was dirt in the injection pump caused by extended (10 months) running on 100% Bio Diesel, perhaps not surprising as it is recycled cooking oil!  I won't risk using it again.
Omegatoy
  • UK
« Reply #5 on: 28 March 2012, 21:36:57 »
great news, looks like the diesel magic loosened the dirt suffiently to let it be pushed out!! :y
