Pages: [1] 2 3  All   Go Down
Author Topic: gearbox oil cooler to cool engine oil instead...  (Read 9350 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« on: 03 March 2012, 20:37:23 »
Hello,
has anybody thought about blanking off the engine oil cooler in the vee and using a gearbox oil cooler rad instead?
alex
V8!!!!
Re: gearbox oil cooler to cool engine oil instead...
« Reply #1 on: 03 March 2012, 20:39:51 »
Hello,
alex
A lot of effort for what gain? The 'cooler' is in effect a 2 way heat exchanger, it helps to raise coolant temp when the engine is cold as well as helping to cool the oil when the engine is hot.  :y
« Reply #2 on: 03 March 2012, 20:46:30 »
if you are going to mod the engine, oil cooler location must be changed for better cooling .. but this brings another problem..
you need a new design ..  :-\
« Reply #3 on: 03 March 2012, 20:49:38 »
Thought there was a cooler stat available? :-\
ngrainqey
  • rotherham
« Reply #4 on: 03 March 2012, 20:52:30 »
im not really suggesting it to do anything other than eliminate the risk of oil cooler failure and contamination of water in oil/ oil in water
alex
V8!!!!
« Reply #5 on: 03 March 2012, 21:01:14 »
As said above, the engine oil warming the coolant is often ever looked. I know I didn't think of it either, until Master pointed it out.
I'm under the impression the optimum temp is 70 to 80 degrees for a tuned engine. Not sure if that's true or why. But if the omega ran that cold it would be a pita in winter.
Later models have a steal oil cooler, I thought these where more reliable?
« Reply #6 on: 03 March 2012, 21:04:08 »
Yep later ones and replacements are stainless steel
« Reply #7 on: 03 March 2012, 21:09:54 »
imo, placing oil cooler in the middle of engine and immersing in coolant not a good design in the first place ..
never seen a japanese car having similiar design..
ngrainqey
  • rotherham
« Reply #8 on: 03 March 2012, 21:31:31 »
+1 CEM, on the volvos the number 1 failure is autoboxes where the engine coolant and gearbox oil contaminate eachother because the gearbox oil cooler runs inside the coolant rad
alex
V8!!!!
« Reply #9 on: 03 March 2012, 21:43:25 »
alex
ATF cooler is in the end of the main rad on MOST cars. But the original question was re engine oil coolers.  ;)
ngrainqey
  • rotherham
« Reply #10 on: 03 March 2012, 21:56:34 »
lol sorry andy...back on topic, thought seeing as i was converting the auto to manual, i'd swap the atf cooler to an engine oil cooler :P
V8!!!!
« Reply #11 on: 03 March 2012, 22:06:13 »
You mean you're thinking of swapping from an oil/water cooler in the V to an oil/water cooler in the main radiator  :-\ :-\ :-\
Samething then ....................  ;) ;)
ngrainqey
  • rotherham
« Reply #12 on: 03 March 2012, 22:14:54 »
nooo lol.... blank the oil cooler off in the vee then have an external oil cooler like the atf cooler currently on it ;) no contamination then mmmm :P
V8!!!!
« Reply #13 on: 03 March 2012, 22:17:31 »
But - unless you've got an aftermarket ATF cooler in there, your ATF cooler is in your radiator? If you've got an aftermarket ATF cooler on there then yeah, you could do the same thing for the oil, though you'd want a thermostatic sandwich plate to avoid over-cooling.
Toyota 1ZZ engines have an oil cooler that's surrounded by engine coolant.
« Reply #14 on: 03 March 2012, 22:23:41 »
first I need to buy from those engines to see.. second another bad design then ;D :P
Pages: [1] 2 3  All   Go Up
