Pages: 1 2 [3]  All   Go Down
Author Topic: gearbox oil cooler to cool engine oil instead...  (Read 9333 times)
Re: gearbox oil cooler to cool engine oil instead...
« Reply #30 on: 04 March 2012, 14:46:00 »
there is a very simple answer to all this, an auto gearbox cooler is designed to withstand virtually no pressure (as the return line to the box simply dumps the oil back into the sump)however your engine oil cooler has to withstand pressures which might reach(on a cold winter morning)100 psi. i'm sure you gentlemen can figure out the implications :y
A very thorough undersealing job and a total-loss oiling system? ;)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #31 on: 04 March 2012, 15:20:57 »
Just realised exactly what model you have. Yes, your ATF cooler is oil/air  :y :y
The Senator did use a small radiator in/under the front driver's side of the car for the engine oil, as suggested by Chris, it used a 'stat in the feed to it from the plate under the oil filter .............. often didn't work though.  ;) ;)
LOL at andy, i did say so to begin with :P
anyway yeah, i dont like the earlier gearbox coolers built into the rads but even the external coolers, how cool do they keep the gearbox oil? it'd tend to get quite hot with sustained higher rpm driving e.g high speed pursuits, trackdays, getting quite enthusiastic on a country road in the case of the older gearbox coolers
alex
V8!!!!
« Reply #32 on: 04 March 2012, 21:42:26 »
Yep.. Save a few pennies and destroy the engine when it goes pop on a cold start with thick oil. Get a proper oil cooler which are much more substantial than the transmission cooler, although you'll still be fixing that which isn't broke, IMHO.
ngrainqey
  • rotherham
« Reply #33 on: 05 March 2012, 09:25:19 »
im not entirely convinced, i know atleast 1 volvo s60r that even has a PAS cooler although it does regular track days
V8!!!!
« Reply #34 on: 05 March 2012, 10:17:52 »
your Omga has a PAS fluid cooler too ............... it's the plain tube at the front of the rad  ;)
« Reply #35 on: 05 March 2012, 10:34:55 »
More importantly, there is a question that has to be asked.....
....what causes an oil cooler to fail.
We all know the answer and we all know how to stop it happening
Pages: 1 2 [3]  All   Go Up
