Pages: 1 2 3 4 5 6 7 8 [9]   Go Down
Author Topic: The Prize!  (Read 23666 times)
0 Members and 5 Guests are viewing this topic.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: The Prize!
« Reply #120 on: 12 March 2012, 19:47:16 »
Or a duff HT lead if you haven't already fitted new ones :y
yep, all new leads mate  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
Re: The Prize!
« Reply #121 on: 12 March 2012, 19:53:02 »
here's the disspac, as i said i just got the 1-3-5 the wrong way round on the drawing ;)
RIP Paul Lovejoy
bored bigyin54
  • south wales
    • black beast
Re: The Prize!
« Reply #122 on: 12 March 2012, 19:58:01 »
i now wish i never had the cam gaskets done it was fine till then :y :y :y
Webby the Bear
  • Northampton
Re: The Prize!
« Reply #123 on: 12 March 2012, 20:00:07 »
We'll sort it bro.  ;)
RIP Paul Lovejoy
Webby the Bear
  • Northampton
Re: The Prize!
« Reply #124 on: 12 March 2012, 20:01:33 »
only other thing....
when fitting the new leads to the spark plugs i simply put them in in length order as there were no numbers on the leads. could that have buggered it?  :-\
RIP Paul Lovejoy
Re: The Prize!
« Reply #125 on: 12 March 2012, 20:43:27 »
Might have.Check the end on the dispack,then mark the number on the lead.Then see if they ae on the correct plugs. :y
Webby the Bear
  • Northampton
Re: The Prize!
« Reply #126 on: 12 March 2012, 20:54:33 »
Cheers Albs, i take it the leads themselves aren't already labelled (if they are i've missed that   :-[) and therefore as long as the corresponding lead is attached to the correct number on the disspac then i can use any lead?
RIP Paul Lovejoy
Re: The Prize!
« Reply #127 on: 12 March 2012, 20:57:51 »
Some leads are numbered, some arent.You can use any one as long as it is in the right place both ends,and obviously is long enough. :y
If they are already in place according to length,it might be easier to make sure the plug lead from number 1 cylinder (for example) is plugged into number one on the dispac.If not move it to the correct place on the dispac rather than move the spark plug end to a different cylinder.Hope that makes sense. ;)
« Last Edit: 12 March 2012, 21:00:31 by Albs »
Webby the Bear
  • Northampton
Re: The Prize!
« Reply #128 on: 12 March 2012, 21:00:08 »
thats what i thought... cheers albus  :y
RIP Paul Lovejoy
Pages: 1 2 3 4 5 6 7 8 [9]   Go Up
Page created in 0.086 seconds with 20 queries.
