Author Topic: Why I like Towing with an Omega  (Read 6238 times)
« on: 04 March 2012, 14:59:11 »
Chap I work with has a 2004 Audi A4 1.9 TDi. Noticed today he was not in it, so asked him about it. Said it blown the turbo on it, common fault apparently on these  ???
Cost of replacement turbo? £400  :o
Add in a little servicing and fitting, £700 bill  :o
Still not fixed, its making more noises now & they think its oil pressure related. So going to Audi for a £150 max fee for a diagnosis on its issue.
Then its going back to the garage to fix what ever is broken  :o
Got less than 100k miles on it to!
I get annoyed at £85 a cam cover bill  ;D
« Last Edit: 05 March 2012, 06:28:34 by Auto Addict »
Re: Why I like Owning an Omega
« Reply #1 on: 04 March 2012, 15:01:04 »
1.9TDi turbos are fairly robust, but often misdiagnosed, and the real fault are the porous vac tubes.
Its a sad fact that Audi dealers are every bit as bad as Vauxhall dealers...
« Reply #2 on: 04 March 2012, 15:02:28 »
I should add, Mrs TB's dad's old A4 TDi, now owned by an ABS member, is on its original turbo, despite several misdiagnosing by "specialists", at 274k...
serek
  • huntingdon
    • 3.2 mv6
« Reply #3 on: 04 March 2012, 15:13:25 »
turbo for 2.2 or 2.0 dti cost same as one for audi
and if you take your omega to VXL or any garage who dont do lots work on omegas you will see big bill too
I do work on cars from VW group and if owner look after them they go easy over 300K petrol or diesel car
sometimes you need some luck with car too :)
hercules
  • sunnyudders
« Reply #4 on: 04 March 2012, 15:21:32 »
why i like owning this isuzu........it just starts and runs and has done faultless for 2 years  8)
im now touching wood  ::)
« Reply #5 on: 04 March 2012, 15:23:15 »
yeah true, I guess the real title for this should be "why i like DIY car work"  :)
£700 though, could buy a whole Omega for that  ;D
« Reply #6 on: 04 March 2012, 16:13:59 »
no surprise.. I have seen passat diesel changing turbo several times without result.. they dont change oil frequently and turbo cooling channels blocked..
« Reply #7 on: 04 March 2012, 16:14:37 »
Half a dozen even. ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #8 on: 04 March 2012, 17:50:20 »
I look after a 54 plate A4TDi that's had just turned 315 k miles last time isaw it, never had any major repairs and still on original clutch :D :D :y
other rides
« Reply #9 on: 04 March 2012, 18:07:43 »
a well looked car and a neglected one will be like day and night..
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #10 on: 04 March 2012, 18:45:19 »
...and don't forget, they're great for towing caravans with.... ;)
I like red cars
Martian
« Reply #11 on: 04 March 2012, 18:55:21 »
Sounds quite reasonable.
Had our 3.1 Bighorn for 3 years and the only money it required (other than basic servicing) in that time was £300 on 2 tyres (BF Goodrich A/T).
« Reply #12 on: 04 March 2012, 21:34:57 »
The biggest issue with that engine is the stupidly long service intervals........if there stuck to then they dont see the high mileage sadly as the 1.9 PD is a pretty good lump
venom
  • South Moreton, Oxfordshire
« Reply #13 on: 05 March 2012, 07:56:14 »
Steady on I know you like your Isuzu, but please keep that info to yourself  ???  ;D
Ken
mathewst
  • Split, Croatia
    • v40
Re: Why I like Towing with an Omega
« Reply #14 on: 06 March 2012, 12:36:53 »
My father has an Skoda Octavia with 1.9tdi engine.
115 000 miles, 11 years old, never a single problem with the car.
Engine is dry like Sahara desert, no oil anywhere.
The only thing to note with these engines is if you had a longer run leave the car iding for half a minute before turning it of.
This helps keep turbo and Bosch pump in good condition
Although I must note that it is bloody awful car to drive  ;D
