Author Topic: Idle problem  (Read 2838 times)
zazun
  • Zagreb,Croatia
    • Omega B 2.0 16v
Idle problem
« on: 06 March 2012, 18:51:11 »
Hi,
I have problem with my car on idle.
for example.
when i driving and go to neutral gear idle goes from 700-1600 rpm . When i stop idle drop down to 700rpm and stay there.
When i move the car 0.5 m idle go again from 700 to 1600rpm.
Problem is when i drive on pertrol and on gas, doesnt metter.
carburator is clean, Idle valve is clean, what next ?
tnx
Denis
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Idle problem
« Reply #1 on: 06 March 2012, 18:59:23 »
idle problems can be caused by vac leaks so i would check there first, spray some carb cleaner around vac pipes and seals/joints/gaskets etc if revs rise you have found the leak  :y
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
Re: Idle problem
« Reply #2 on: 06 March 2012, 19:15:12 »
have a look at your EGR valve if the bolts have become loose threaded as 2 of mine were on my v6
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
zazun
  • Zagreb,Croatia
    • Omega B 2.0 16v
Re: Idle problem
« Reply #3 on: 06 March 2012, 19:20:35 »
ok i try that. No change in idle throttle. Nothing happens.
I checked the intake manifold and air filter box. Nowhere draws excess air.
I remembered something else, sometimes the car is ok, but when you power off and after 5 minutes start on idle goes crazy.
might be a problem in fluid temperature sensor, but where it is located.
Denis
zazun
  • Zagreb,Croatia
    • Omega B 2.0 16v
Re: Idle problem
« Reply #4 on: 06 March 2012, 19:24:03 »
EGR valve ?
No i didnt. where i can find it, and hot to check EGR ?
tnx
Denis
supersaw
  • Lithuania
    • 95' Omega, 2.0 16v + LPG
    • MappingTracking.com
Re: Idle problem
« Reply #5 on: 06 March 2012, 19:30:44 »
My omega had a similar problem: revs jumped 700-3000 rpm... I cleaned EGR and know it runs smooth.
Horsepower is how fast you hit the wall
Torque is how far you move that wall
Elite_L0ver
  • On too Omega #2
Re: Idle problem
« Reply #6 on: 06 March 2012, 19:36:07 »
EGR valve ?
tnx
Denis
it is on the drivers side of the plenium held on by 3 bolts behind throttle cable on british migs
supersaw
  • Lithuania
Re: Idle problem
« Reply #7 on: 06 March 2012, 19:39:42 »
I found great link how to clean this valve.
http://www.omegaowners.com/forum/YaBB.pl?num=1194007453/0
Re: Idle problem
« Reply #8 on: 06 March 2012, 19:54:05 »
Make absolutley sure the breathers, throttle body and drillings and the idle valve are clean.
If the breathers and associated drillings are clogged, the idle valve will also quickly clog.
Plnety of guides on here telling you how to do it
Abiton
Re: Idle problem
« Reply #9 on: 06 March 2012, 20:52:17 »
EGR valve ?
tnx
Denis
Not on a 2.0/ 4-pot.
EGR valve is right at the back of the head, next to to the DIS.  This picture also shows the position of the temperature senders.
I'm not sure that an EGR fault can cause your symptoms, but I can't see any harm in giving it a clean.
Grumpy's guide is definitely the thing to follow for IACV and breather-jet cleaning, but sometimes won't completely solve the problem if the idle (air control) valve is worn.  If you can borrow another IACV that is known to be working, to try on your car, that might be useful.  A cheap pattern replacement IACV lasted faultlessly for about 4 years until the death of our mig.
« Last Edit: 06 March 2012, 20:58:03 by Abiton »
