Author Topic: Struggling to pull off in 1st ( Corsa 1.2)  (Read 6857 times)
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
« on: 11 March 2012, 13:10:16 »
Hi all, the wifes Corsa is struggling to pull away in first, once it gets going its ok, untill the next junction.
any ideas?????
Jon :y
Jon
Re: Struggling to pull off in 1st ( Corsa 1.2)
« Reply #1 on: 11 March 2012, 13:21:13 »
What happens? Is it clutch slipping or the actual first gear not seeming to work?
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
« Reply #2 on: 11 March 2012, 13:25:25 »
I don't know, just went round the block then, pulled off ok, a bit of  a struggle to put in to 2nd, then when I pulled off at next junction it struggled in 1 st again. could be clutch problem I guess.
Jon
« Reply #3 on: 11 March 2012, 13:26:53 »
Do the revs rise but no movement?
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
« Reply #4 on: 11 March 2012, 13:32:12 »
I'm getting movement, but feels like its about to or does cut out, you can gently tease it to pull away, then bingo, we're off as normal.
Jon
« Reply #5 on: 11 March 2012, 13:36:28 »
So not the revs rising rapidly with little movement?
OK... Can't remember if they are cable or hydraulic clutches on the Corsa but it sounds like a clutch issue. Could be the operation of the clutch or could be that the clutch internals are hanging up. :-\
If hydraulic, my first point of call would be to check the fluid and bleed it ;)
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
« Reply #6 on: 11 March 2012, 13:39:03 »
Thats me stumped straight away  :-\, I will have to explore a Corsa site for engine pics lol.
Jon
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #7 on: 12 March 2012, 09:29:14 »
Is the struggle actually pulling away or finding first and second gears,if its the latter there is a modified gear linkage that cures that for about £50 plus fitting which is easy
other rides
Dr_X
« Reply #8 on: 12 March 2012, 10:05:13 »
Just a thought but are the brakes binding??? my mother has got a corsa and sometimes the handbrake can stick a bit...just a thought
andyc
  • Norfolk
« Reply #9 on: 12 March 2012, 16:57:44 »
Sounds more like the gear linkage is shot and your pulling away in third not first as the gear shift indicates
Cheers
Andy
Thetford. Norfolk
« Reply #10 on: 12 March 2012, 17:04:57 »
Indeed, whats the speed at certain rpm's in first......repair kit for the linkage is cheap enough and easy to fit.
