Author Topic: 2.5TD auto locked in P  (Read 1257 times)
mc9
  • Luton, Beds
« on: 11 March 2012, 18:52:51 »
The gear selector lever is sometimes getting stuck in the P position and doesn't allways release when footbrake is applied. I know how to release it manually by pressing the yellow trigger under the selector lever gaiter.
Other threads suggest a bad brake light switch is the probable cause. Is there a way to permanantly disable this annoying "safety" feature? I guess I could hold the trigger down with sticky tape or similar. Can anyone suggest anything better?
Thanks
mc9
Re: 2.5TD auto locked in P
« Reply #1 on: 11 March 2012, 20:02:42 »
First prove where the fault lies ;)
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #2 on: 11 March 2012, 21:06:06 »
Had an auto Vectra do a similar trick and also when going from N to D. Turned out that I'd lost both side brake lights - only high level working. Fitted new bulbs and all good....just a thought.
Those are my principles, if you don't like them I have others.
