Author Topic: camshaft sensor  (Read 2449 times)
mantamania
  • Chatham, Kent
    • 2.6 Elite
camshaft sensor
« on: 11 March 2012, 22:23:11 »
Hi all,
I have just done a cylinder head gasket on my 2.2  When it came to start the engine, it would not fire up. The only fault that registered was for the cam-sensor.
Do camshaft sensors just check for rotation of the camshafts or do they check that the timing is ok?
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
Re: camshaft sensor
« Reply #1 on: 11 March 2012, 22:28:57 »
I maybe wrong I'm not overly familiar with the 2.2 but I think the ecu uses the cam sensor to fire the injectors during start up. I know the v6 will run with it unplugged but not start.
    • 530D M Sport, 330i Coupe
Re: camshaft sensor
« Reply #2 on: 11 March 2012, 22:31:26 »
Will run on just crank sensor but will be a bugger to start and will run in limp mode.
mantamania
  • Chatham, Kent
    • 2.6 Elite
Re: camshaft sensor
« Reply #3 on: 13 March 2012, 17:55:32 »
Today i fitted a new cam sensor but the car does not start.  Traced the wiring back to the ECU and found no breaks in the wires.
doz
  • Southampton
Re: camshaft sensor
« Reply #4 on: 13 March 2012, 17:57:03 »
Are you still getting a cam sensor error code
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
Re: camshaft sensor
« Reply #5 on: 13 March 2012, 18:00:16 »
any more codes?last time i had this,it was the crankshaft sensor...engine ran with a faulty cam sensor,but wouldnt start with a faulty crank sensor...coil pack connected ok?
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
Re: camshaft sensor
« Reply #6 on: 13 March 2012, 18:02:31 »
was it a genuine gm cam sensor..?
Re: camshaft sensor
« Reply #7 on: 13 March 2012, 18:08:48 »
Is cambelt timing correct?
mantamania
  • Chatham, Kent
    • 2.6 Elite
Re: camshaft sensor
« Reply #8 on: 13 March 2012, 18:11:40 »
Hi all,
I used a genuine GM sensor, and still got p0340 fault code, no other codes listed.
