Author Topic: coolent leak  (Read 1525 times)
ree
  • Cambridge
    • omega 2.0 cd
coolent leak
« on: 11 March 2012, 23:29:27 »
Hi all ree here again ive had a leaking coolent  from which i thought was at rear of engine as saw red fluid stain around that area.
took front skuttle off could,nt really see to much felt all round pipes so forth its not a bad leak prob once a week top up i turneed engine on for awhile full heating on still could not find leak / its not water pump or anything to do with rad , worried might do casket in if not found and fixed. do i need a pressure test to find it ?? or is there somewhere i havent looked ,as its hard to tell as been leaking awhile so fluid well over much of the back end of engine , heres hopeing  Ree
REELUIN
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: coolent leak
« Reply #1 on: 12 March 2012, 06:04:44 »
Insert Quote
take scuttle off by windscreen, looking in engine bay rear left of engine is where the hbv lives, pain to see and get at  :( but a coolant leak usually points to the hbv fubared and leaking, if not hbv your best bet is as you have said pressure test the system but put your heater through all operations as you are doing it  :y
Re: coolent leak
« Reply #2 on: 12 March 2012, 19:47:44 »
Probably HBV mate at back of block drivers side - see http://www.omegaowners.com/forum/index.php?topic=90574.0 for advice on replacing. :y
Whats with the large blue letters mate - most of us don't need specsavers yet  ???
RobseyMV6
  • west sussex
Re: coolent leak
« Reply #3 on: 12 March 2012, 20:13:26 »
What years your omega, could be leaking from head gasket passager side, leaking out-wards not into cly common problem to, have done many.
fiend61
  • york
  • each to their own
Re: coolent leak
« Reply #4 on: 12 March 2012, 21:45:07 »
on a  v6  ?? not very common i would think  :-\
Re: coolent leak
« Reply #5 on: 12 March 2012, 22:10:36 »
Not that uncommon on 98 3.0 for some reason. ;)
