Author Topic: Wired emulator, lost some reception.  (Read 7516 times)
« on: 12 March 2012, 09:23:35 »
Any fix? It's an ncdc 2015 in a saloon. Afaik the aerial is the rear window heater element, and the aerial/mouse on the roof is for the phone.
Does the radio aerial have an amp to boost signal? If so can it be tweaked or a more "boostyer" one be fitted?
Ta
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Wired emulator, lost some reception.
« Reply #1 on: 12 March 2012, 09:34:00 »
Sadly, unlike external antennas, the signal strength from the internal rear screen aerial is of such poor quality, that the use of inline modulators is really not advised, as the extra joints and circuitry degrade the signal even further to a point that it is too weak for the head unit to receive.
Any boosters will just give more "Mush" as the signal is too poor to start with.
either External aerial or Wireless modulators are the way to progress forwards
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #2 on: 12 March 2012, 14:40:59 »
Any insertion loss specs for the modulator?
Connector insertion loss should be of the order of 0.3dB
« Reply #3 on: 12 March 2012, 16:55:28 »
I reckon it matches mine, for reception, and no uphill gardener HK unit in mine ;)
« Reply #5 on: 13 March 2012, 08:22:49 »
Sadly nothing in there.
A basic setup could be resistive so quite lossy, slightly more advanced would use a transformer which are good from an insertion loss perspective.
A good system would be electronic!
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 13 March 2012, 08:58:18 »
Change the roof aerial for an aftermarket tri-state one,  GSM/GPS/FM  and the signal will certainly improve.
Hirschmann and Bosch are worth searching for
« Reply #7 on: 13 March 2012, 10:27:27 »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #8 on: 13 March 2012, 10:51:39 »
This one any good?
http://www.bluespot.co.uk/car-audio.aspx/arpndt01m-aerial
With tv ;)
Yep, thats the sort of thing, although it must be said that you can get them without the Chav Fin if you wanted it to look more like the original antenna.
BTW, the TV side is redundant here, as was intended for analogue, not diigital !! Which may offer a good bargaining chip as the aerial is now obsolete !!
« Reply #9 on: 13 March 2012, 11:10:59 »
Dab, no? :-\
« Reply #10 on: 13 March 2012, 11:16:16 »
This one any good?
With tv ;)
That one says it's discontinued, but apart from that minor issue.. if you find one at a decent price (i.e. less than the OE aerial base), see if they'll offer a discount for two - I could be tempted seeing as how I broke my OE base  :-[
« Reply #11 on: 13 March 2012, 11:19:50 »
Was trying to avoid the BMW type shark fin ones tbh. :(
« Reply #12 on: 13 March 2012, 11:22:58 »
I'm not all that fussed about looks - I went looking for a suitable replacement before (actually, I think Dave pointed me to one) but the price was somewhat eye watering and pretty similar to the OE replacement price :(
« Reply #13 on: 16 March 2012, 18:22:36 »
Lost all reception now, emulater as well. Bit of soldering at the weekend by the looks...
I've been meaning to have the HU out for a while now anyway, as the cc temp knob has gone all unresponsive again, air flow sensor was found to be dislodged when the emulator was wired up.
Another job for the weekend. Sigh... ;D
« Reply #14 on: 16 March 2012, 23:16:43 »
Nope, scratch that, emulater was on pause  :-[ ;D
Page created in 0.009 seconds with 21 queries.
