Author Topic: Brake pad thingy ?  (Read 4130 times)
Brake pad thingy ?
« on: 12 March 2012, 16:15:13 »
Did a thorough inspection and clean of the handbrake drum and shoes yesterday . I took the brake PADS out to clean and apply copperease but on one side the metal retainer on the back was falling to bits "is it called anti rattle thingy ?" anyway this was the cause of the sound of me dragging cans along  behind me .
So not having a replacement metal thing i left it off but should i replace it asap or will it be ok to leave off  ;)
Dr_X
Re: Brake pad thingy ?
« Reply #1 on: 12 March 2012, 16:24:17 »
I binned them when I did the wifes the other day.....but the new pads did have like a rubber pad on the back side......I wouldn't lose any sleep over it.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #2 on: 12 March 2012, 16:27:28 »
Personaly never fitted them.
Always made sure the caliper was clean and put plenty of copper slip on the back to stop them sticking  :y
« Reply #3 on: 12 March 2012, 16:36:29 »
Nice one  ;) I copper greased the back of the pads and a small smear on the pins . Lovely and quiet now what with the new drop links and track rods and no rattle rattle from that plate catching the disc . Handbrake adjusted as well ...smashing  ;)
« Reply #4 on: 13 March 2012, 10:40:04 »
I would (and do) refit (or replace if its unusable).
« Reply #5 on: 13 March 2012, 11:52:05 »
What are they for though  :-\
« Reply #6 on: 13 March 2012, 11:57:53 »
I'm going to go out on a limb here (not having done a pad change on mine yet, despite the rampant squealing) - anti squeal shims.
A good smearing of copper grease probably achieves the same thing, at least until it dries out and starts to squeal like a stuck pig.. but if you're a bit of a stickler for doing things 'right' then it's not 'right' without it. If you see what I mean.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #7 on: 13 March 2012, 12:02:24 »
So would I. GM must have had their reason to put them in and they do have a price so if they were not needed they would not have been fitted in factory.
« Reply #8 on: 13 March 2012, 12:07:31 »
Will refit new ones when pad replacement is needed , always wondered what they were called . I take it by not having them its not an MOT fail  :-\ I have copper greased the pads .
« Reply #9 on: 13 March 2012, 12:11:39 »
Nah - not an MOT fail, the pads just might start squealing prematurely :) Assuming I'm right about them being anti squeal shims, of course! Based on the description, though, that's all I can see them being.
Some pad manufacturers (notably EBC) give you a chunk of the rubberised stuff to stick on their pads instead (though on the MR2 I recycled the OE shims instead), anyway :)
« Reply #10 on: 13 March 2012, 12:17:52 »
The passenger side rear one was only half intact and was rubbing on the disc causing the sound like i was draging bake bean tins along  ::)  it just fell out with a poke  ::)
« Reply #11 on: 13 March 2012, 12:24:16 »
They stop the pads rattling around in the caliper, when applying the breaks you may well get a click/knock/clack type noise as the disc moves the pads forward and back.
There may not be much play where the pads sit in the caliper, but you can bet there will be soon enough with no springs at all.
Best to fit them, doesn't take long.
« Reply #12 on: 13 March 2012, 12:31:31 »
I had the clicking of the pads quite a bit before i cleaned the caliper pins and brake pads but since re fitting without the anti squeal plates its stopped ..must be the copper grease i applied. Advice understood though , will refit on replacement
« Reply #13 on: 13 March 2012, 12:34:43 »
This copper slip is incredible stuff. Wonder what else it will fix...?
« Reply #14 on: 13 March 2012, 12:35:22 »
It fixes everything! Except for OOF-crippleitis, sadly. ;)
