Pages: [1] 2 3  All   Go Down
Author Topic: Front wheels  (Read 8418 times)
mega3.0v6
Front wheels
« on: 12 March 2012, 18:23:54 »
Could somebody help me please....
I getting to point of insanity, I have changed wishbones twice now put polybushes in the front bush of the wishbone.
Had 4 wheel alignment (spelling)
And today i find this:
O/S
N/S
Now the problem i have been having is when braking it was pulling to the left since fitting polys it is i'd say 95% better on braking, What could be causeing this with the nearside wheel a little bit further back than the offside.
Thanks in advance.
Agemo
  • Cleethorpes
  • Insignia
Re: Front wheels
« Reply #1 on: 12 March 2012, 19:17:32 »
Yep, your castor angle is out, where did you have the alignment done?
mega3.0v6
Re: Front wheels
« Reply #2 on: 12 March 2012, 19:20:27 »
Ats with some new 4 wheel alignment kit.
Agemo
  • Cleethorpes
  • Insignia
Re: Front wheels
« Reply #3 on: 12 March 2012, 19:24:08 »
I would go back & ask if they checked your camber or castor.
Re: Front wheels
« Reply #4 on: 12 March 2012, 19:31:34 »
I would go back and ask for your money back, then book it into WIM at Chesham .. seem to be the only folk who know what they are doing !!
Re: Front wheels
« Reply #5 on: 12 March 2012, 22:03:23 »
thats a big difference.. and I dont think it a simple misalignment problem :-\
Agemo
  • Cleethorpes
  • Insignia
Re: Front wheels
« Reply #6 on: 12 March 2012, 22:08:17 »
Are you thinking the subframe could have moved?  :-\
Re: Front wheels
« Reply #7 on: 12 March 2012, 22:23:23 »
WIM move the subframe to adjust castor ... so if it's "moveable" it might have "moved" on it s own .. or someone has been messing ......
Needs a "proper" setting up by someone who knows what they are doing IMHO
Re: Front wheels
« Reply #8 on: 12 March 2012, 23:15:58 »
As said subframe position needs correcting. Might also be caused by accident damage.
However, I've seen worse on my own cars with no pulling on the brakes.
So it's important to correct that issue first obviously.
Question no. 1. How tight are the wishbone bolts? I'm looking for a torque wrench setting figure. :)
Re: Front wheels
« Reply #9 on: 13 March 2012, 14:07:34 »
have seen lots of cars worse than that.. generally big potholes or accidents can cause that..
my clit had that when I bought it.. and it required to visit to a chasis correction shop.. :-\
ps: never seen it on a miggy but before moving subframe, some distances must be measured ..
« Last Edit: 13 March 2012, 14:09:11 by cem »
Re: Front wheels
« Reply #10 on: 13 March 2012, 18:01:19 »
4 wheel alignment is as much use as a used johnny, smear in dogshit. Utterly pointless. At best, if the retards know how to use it, it only ensures that the rear wheels follow the front, irrespective of where the front my point.
Given your location, try WIM in Chesham. Mention OOF when booking for discount.
mega3.0v6
Re: Front wheels
« Reply #11 on: 14 March 2012, 14:12:35 »
If i remember i did torque bolts upto 210nm.
Re: Front wheels
« Reply #12 on: 14 March 2012, 15:00:36 »
120nm plus angle tighten 30 degrees then a further 15 degrees
Dr_X
Re: Front wheels
« Reply #13 on: 14 March 2012, 15:07:21 »
Plus you must do them up with the full weight of the car on them....
Re: Front wheels
« Reply #14 on: 14 March 2012, 15:10:45 »
Not with polly. Doesnt matter.
Oe bushes yes, wheels must be loaded with suspension arm sitting at correct ride hight.
Pages: [1] 2 3  All   Go Up
