Author Topic: Camshaft experiments - advice needed  (Read 3837 times)
2woody
  • Northumberland
« on: 12 March 2012, 20:45:00 »
Right, so I've got two cars here and some time - I'm intending to get to the bottom of this 3-litre cams thing. I'll do a couple of dyno runs per vehicle in just about the same conditions as I can manage
2.6 manual. Standard configuration and then swapped for which cams ?
3.0 manual. Standard and then which cams ?
Re: Camshaft experiments - advice needed
« Reply #1 on: 12 March 2012, 21:10:08 »
 From what I've read
2.6 to 3.2 cams
3.0 cams not worth fiddling with.
« Reply #2 on: 12 March 2012, 21:12:17 »
Had similar thoughts re a stainles exhaust on a car here. He said it was faster. But it's just louder afaict.
I was going to Dyno it, but can I be arsed...?
« Reply #3 on: 12 March 2012, 21:49:46 »
2.6 to 3.0 cams (or 3.2)
3.0 replace the exhaust cams with inlets .....will be interesting to see if it makes any difference  :y
2woody
  • Northumberland
« Reply #4 on: 13 March 2012, 21:16:12 »
that's what i thought - care to add the cam identification letters to that ?
serek
  • huntingdon
    • 3.2 mv6
« Reply #5 on: 13 March 2012, 21:27:30 »
I have set off custom made camshafts for omega V6 fancy try them??
« Reply #6 on: 13 March 2012, 21:27:57 »
2woody
  • Northumberland
« Reply #7 on: 13 March 2012, 21:29:35 »
can do, yes.
I'm specifically testing the theory that 3.0 cams in a 2.6 will add to the power without a re-map, so I'll be testing if your cams make any more power in an Omega without a re-map.
what spec are they ? are they compatible with standard valve springs ? will they cause piston clearance problems ? how should they be timed up ?
« Last Edit: 13 March 2012, 21:33:02 by 2woody »
serek
  • huntingdon
    • 3.2 mv6
« Reply #8 on: 13 March 2012, 21:34:11 »
can do, yes.
Pm you address and I send them over in monday or when you want
serek
  • huntingdon
    • 3.2 mv6
« Reply #9 on: 13 March 2012, 21:38:50 »
can do, yes.
they have nearly same lift as standard cams so can use strandard valve springs and timing its same as normal cams
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #10 on: 13 March 2012, 22:48:43 »
Was it Martin Imber that had 3ltr inlet cams on a 2.6 ?
« Reply #11 on: 13 March 2012, 23:36:49 »
He might have mentioned how fast it was once or twice. ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #12 on: 14 March 2012, 18:28:37 »
I had 3.0lt cams in my 2.5 and it was noticeably better past about 3.5k revs but didn't notice anything below that :( which is where an auto could have done with more oomph.
other rides
Page created in 0.028 seconds with 20 queries.
