Author Topic: Light Flywheel V6  (Read 11227 times)
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
Re: Light Flywheel V6
« Reply #16 on: 22 May 2012, 20:36:34 »
Just faster engine response, really. You might find slightly quicker acceleration in the lower gears, but the main reason to do it is to allow the engine revs to fall faster from the red line as you change up the gears, and for quicker response when "blipping" the throttle to match the revs on downshifts.
It won't affect engine braking or economy.
I was lead to believe that with a lighter mass of the flywheel, you gain engine braking???
Which I think is almost non existent on the Omega, well it is on mine anyway???
« Last Edit: 22 May 2012, 20:38:42 by HockeyDave55 »
GmasterT
  • Cambridge
  • does that drifting thing...
« Reply #17 on: 22 May 2012, 20:47:51 »
Silky smooth free revving equal balance 6 cyl makes it feel like that :)
MPGs may increase but not really noticably, just less turning mass on the engine etc, same as losing the air/con pump (no on)
Diameter would be the same, or the starter wouldnt work :)
opelfreek
  • Norway
« Reply #18 on: 24 May 2012, 10:31:26 »
Is it a straight swap then? It was the outer that I was referring to....
I need to do something as my DM is buggered! Clank, clank....
Also, I'm guessing the point of this mod is faster engine response, better engine braking and maybe impoved fuel economy???
[/quote]
Yes it was an straight swap. I don`t know the outer diameter..
Haven`t got the engine and the new flywheel in the car so i don`t know how it is going to work  :o
opelfreek
  • Norway
opelfreek
  • Norway
« Reply #20 on: 24 May 2012, 10:34:52 »
hi sorry for late replay,
the vectra
B V6 clutch plate its the cheapest option and easy to find on ebay form like 5£
[/quote]
Mkey... i havent found anything on ebay. Mabye i hav to search some more then :)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« Reply #21 on: 21 February 2013, 20:28:58 »
How did you get on doing this?
serek
  • huntingdon
    • 3.2 mv6
« Reply #22 on: 21 February 2013, 20:41:25 »
just out of intrest why you want fit solid fly wheel??
P6UL K
  • Dartford, Kent
« Reply #23 on: 21 February 2013, 21:05:25 »
DMF has had it and this suits my pocket!
