Author Topic: omega on 20"  (Read 4555 times)
serek
  • huntingdon
    • 3.2 mv6
omega on 20"
« on: 28 March 2008, 21:03:09 »
Marie
    • 2ltr LPG Estate
Re: omega on 20"
« Reply #1 on: 28 March 2008, 21:07:15 »
surely that cant be goo for the tyres ;D ;D ;D
i thought i read somewhere you couldnt go bigger then an 18" cos it starts to effect the ride comfort/smoothness. :-?
markey mark
  • SLady bitshorpe north lincs
Re: omega on 20"
« Reply #2 on: 28 March 2008, 21:21:26 »
i have 19"s on mine marie still rides spot on and handles ace  :y :y
Marie
    • 2ltr LPG Estate
Re: omega on 20"
« Reply #3 on: 28 March 2008, 21:23:12 »
oh ok id like to change my wheels but i think its going to have to wait till next year now.
but it give me time to save up and find a set i like, well we both like.
Re: omega on 20"
« Reply #4 on: 28 March 2008, 22:34:33 »
Please forgive if this is a daft Q, but how do you do that?
I can understand pressing the brake and theengine will still turn the rear wheels but this must wreck the back brakes. :(
And or do those that do this a lot have a spererate front wheel only brake?? :-[ :-[
Re: omega on 20"
« Reply #5 on: 28 March 2008, 22:49:25 »
You can fit a device called a line-lock to the front brakes. Effectively just a valve that allows you to hold the fluid pressure in front brakes only. Not that I'm into such activities but I did witness an amusing burn-out competition at Le Mans where various exotica (with clueless drivers) attempted to do the same and failed due to too much grip or even just a failure to turn off the TC.
Then.. along came some likely lads in a beaten up "B" reg Fraud Sierra with the rear window fabricated from some attractive polythene.
Anyway, they had made 3 modifications to this vehicle from what I could see:
Fit the cheapest, hardest tyres they could find.
Fit a line lock
Fit a V8.
Needless to say, once the laughter had died down they left rubber for about 1/2 the length of the Mulsanne straight and left egg on a few faces too. ;D
Re: omega on 20"
« Reply #6 on: 28 March 2008, 23:08:02 »
Fit a line lock
Fit a V8.
Thanks for that Kevin, story about the Ford, make sense, I like the idea of 'sleepers' always have, even from young. Best I ever did was a V6 into a Cortina Mk2, standard back axle and gear box, that could leave rubber. One day will do something.  ;D ;D ;D
Re: omega on 20"
« Reply #7 on: 28 March 2008, 23:26:10 »
Fit a line lock
Fit a V8.
Back in the 60s stuffed a 3.8s Jag engine & box into a 105e Anglia - had to fit lotus cortina ˝ shafts as it bust the std ones first try out.  Top speed around ton due to anglia back axle but bl**dy fast getting there!  Wonder where it is now!!
Re: omega on 20"
« Reply #8 on: 28 March 2008, 23:27:15 »
Fit a line lock
Fit a V8.
That's a conversion. ;D ;D ;D
Re: omega on 20"
« Reply #9 on: 28 March 2008, 23:29:35 »
Fit a line lock
Fit a V8.
Fun to drive - steer it on the throttle.  Could do a set of rear tyres in 250 miles!
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
Re: omega on 20"
« Reply #10 on: 28 March 2008, 23:33:28 »
Once had an old ford corsair 2.0 V4, swapped it out for the 3.0 Essex V6.
looked like a piece of lime green snot....   but was bastard quick....   ate clutches though.,...  :D
Re: omega on 20"
« Reply #11 on: 29 March 2008, 00:24:03 »
Speaking of crazy conversions I was thumbing through Practical Performance Car in the newsagents this lunch time and saw an article where someone had put a BMW Tractor lump from an Omega into a Reliant Scimitar. :-/
davlad22
  • Sunny Yorkshire
Re: omega on 20"
« Reply #12 on: 29 March 2008, 01:44:56 »
Been posted up before, one of our european friends I think?
Re: omega on 20"
« Reply #13 on: 29 March 2008, 10:35:11 »
He clearly didn't speak to TheBoy first. ;D
Bit of a shame has he had the carve the car up a bit to get it in there. Why, oh, why didn't he put a 3.2 V6 into it?  :-/
Paulus
  • Wheaton Aston
  • Are you lookin' at me??? Punk???
Re: omega on 20"
« Reply #14 on: 29 March 2008, 13:03:16 »
Why can't I do that with my car?
(the wheelspin, not the alloys).
Growing old disgracefully...
