Author Topic: ABS light on  (Read 3072 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
ABS light on
« on: 19 March 2012, 12:43:21 »
Hi guys, sadly ABS light blinks from time to time and speed/rpm gauges drop dead when this hapens.
Is it definately an ECU issue or maybe abs sensor going?
Any advice is welcome because I've just changed oil and need car for a long trip....
Thanks :-[
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: ABS light on
« Reply #1 on: 19 March 2012, 12:47:36 »
would need the abs to be read but look at the back sensors and clean the cogs make sure there is no muck between them.
Solar charger fitted.
If not Broke dont fix it..
danzigfan
Re: ABS light on
« Reply #2 on: 19 March 2012, 12:59:19 »
Thanks, just a question more, are those sensors the ones just by the drive shafts?
danzigfan
Re: ABS light on
« Reply #3 on: 19 March 2012, 13:02:24 »
freecall666
Re: ABS light on
« Reply #4 on: 19 March 2012, 13:10:09 »
yeah either side of the dif. should be nothing inbetween them.
freecall666
Re: ABS light on
« Reply #5 on: 19 March 2012, 13:15:11 »
oh right, if it is that fault take the battery off and leave it off for a few hours had this on mine a long time ago dont know what caused it but when had battery off wile was looking for the fault could not find any thing wrong had the abs plug off the unit put it all back on and the fault was gone, had a few cups of coffee's..
danzigfan
Re: ABS light on
« Reply #6 on: 19 March 2012, 13:19:26 »
Ok then, I'll take the batery off and take a look at the sensors while praying for a fault like your's was
Thanks, I'll update the results
F1 9LFG
  • nr Braintree, Essex
Re: ABS light on
« Reply #7 on: 19 March 2012, 22:29:16 »
I had the same problems that you mention, it turned out to be the ABS ECU. even though it wasn't symptomatic of an ECU failure it was! Pleased if it is a sensor / sensor wire though  :y
danzigfan
Re: ABS light on
« Reply #8 on: 20 March 2012, 20:57:04 »
ABS sensors are clean now, been really dirty and greasy, time will show what to expect.
Thanks again
F1 9LFG
Re: ABS light on
« Reply #9 on: 20 March 2012, 21:00:37 »
Thanks again
Pleased to hear it. wouldn't wish a DIY ABS ECU change on anyone!  :y
Re: ABS light on
« Reply #10 on: 20 March 2012, 21:01:59 »
Thanks again
Done my first one on a V6 thought it was quite easy Rob :)
F1 9LFG
Re: ABS light on
« Reply #11 on: 20 March 2012, 21:06:45 »
Thanks again
Your clearly more 'able' than me Rob, I spent 4hours of sweat, blood, tears and dropped nuts/sockets changing mine. Prey to god that I don't have to replace it again. (if it fails again I know who to turn to now!)
