Author Topic: MV6 Rear Suspension Springs  (Read 2902 times)
farty_towels
  • Plymouth
  • Lively up yerself...!
    • MV6 Elite 3.0 2000
« on: 20 March 2012, 00:11:17 »
You can probably tell by now that I'm no mechanic, but following a failed MOT, my mechanic tells me that a rear suspension spring has broken and will cost £90 to replace to get the MOT pass. Furthermore he recommends that I get both sides done at the same time (double the money).
Does this sound right guys?
Cheers...
Ade
Of all the things I've lost in life, its my mind I miss the most...!
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: MV6 Rear Suspension Springs
« Reply #1 on: 20 March 2012, 00:16:11 »
would recomend it as when one side gose its not long and the other side can go. and you dont want to be on long drive when it go's.
and £90 is not bad i payed more than that, as did not have time to doit my self.
Solar charger fitted.
If not Broke dont fix it..
farty_towels
  • Plymouth
« Reply #2 on: 20 March 2012, 00:18:28 »
Cheers freecall, would you think the price is about right?
« Reply #3 on: 20 March 2012, 00:18:49 »
Yes. Although... Does he say which springs particularly? There's some real crap about thats not worth fitting.
It is always recomended that stearing and suspension components be changed in axle pairs. Where applicable. Uneven performance can result. In your case, a lopsided car.
freecall666
« Reply #4 on: 20 March 2012, 00:19:41 »
mine was over £200 so £90 each side is not bad.
farty_towels
  • Plymouth
« Reply #5 on: 20 March 2012, 00:21:27 »
He said that the 'heavy duty' ones were about £90 each fitted...
the other one look fine though...?
freecall666
« Reply #6 on: 20 March 2012, 00:27:28 »
should be fine just check the thicknes of the new ones to the old ones.
« Reply #7 on: 20 March 2012, 00:35:53 »
Depends what's on there currently. Noticing yours is an mv6, which if face lift, runs a 15 mill lower ride hight than stock , you may find the front will be noticeably higher with heavy duty springs.
If pre/mini face lift, standard springs are used with different shocks than standard.
I'd suggest Kyb as a minimum quality.
« Reply #8 on: 20 March 2012, 17:10:07 »
I would fit KYB or Boge, the facelift MV6 ones are lower than normal
« Reply #9 on: 20 March 2012, 20:04:30 »
why was I thinking front springs when I wrote this...? Apologies.
As Tunnie says. ;)
« Reply #10 on: 20 March 2012, 22:00:27 »
Confirm, replace in pairs...
