Author Topic: Cheapest place to buy Front flex section exhaust for 2.2 petrol  (Read 4740 times)
Re: Cheapest place to buy Front flex section exhaust for 2.2 petrol
« Reply #15 on: 20 March 2012, 22:44:44 »
That`s a 2.0 downpipe, how did you fit the first lambda sensor
bored bigyin54
  • south wales
    • black beast
« Reply #16 on: 20 March 2012, 22:47:55 »
i didnt thats the way it was when i got it :y :y :y
« Reply #17 on: 20 March 2012, 22:55:11 »
Your car should have 2 lambda`s, one screwed into the pipe before the pre-cat, the other after the main cat. When you fitted the new downpipe what did you do about the wiring harness that was connected to your original pre-cat lambda sensor :-\
OmegaAnglesey
« Reply #18 on: 21 March 2012, 02:49:55 »
I got the whole front section (downpipes & 2 cats up until the rear box) for about £160 from EuroCarParts).
They seem to change their prices depending on how they are feeling, so just ring around a few different branches, and when you get quoted a price, ask if they can do anything for you... You will probably find each branch will quote you a way different price...
Slightly cheaper than Vx £1000 jobby... Sounds the same, are certified, and guaranteed for 2 or 3 years.. cant remember exactly...
Don't bother welding the flexi... You cant get a decent seam and it will be a temp fix at best...
i only got one cat on mine thats a 2.2
2 Ralf, pre-cat and main cat
that looks the same as mine.
bored bigyin54
  • south wales
    • black beast
« Reply #19 on: 21 March 2012, 08:43:57 »
like i said rob thats the way i got the car i dont know where its gone ??? ??? ??? ??? ??? i only done from cat back
« Last Edit: 21 March 2012, 08:54:17 by bigyin54 »
« Reply #20 on: 21 March 2012, 09:00:06 »
yes thats mine  :y :y :y :y maybe thats why my spanner light comes on now and again :y :y :y
You already have a cheap crap non gen cat fitted then, from bitter experience these dont last two minutes and often fail the emmisions test after a year or two.
I would pruchase the genuine one whilst you can.
« Reply #21 on: 21 March 2012, 09:00:46 »
You need to practice your welding some more  :y
bored bigyin54
  • south wales
    • black beast
« Reply #22 on: 21 March 2012, 09:02:42 »
i will when i got loads of money which isnt at the moment  ;D ;D ;D ;D
bored bigyin54
  • south wales
    • black beast
« Reply #23 on: 21 March 2012, 16:29:37 »
i just found out of my son there is a second wire after the cat and wired up to the sensore so i got one before the cat and after the cat :y :y :y :y
