Author Topic: Was I mad?  (Read 1805 times)
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
Was I mad?
« on: 31 March 2008, 16:18:56 »
A couple of weeks ago I decided to change the spark plugs on my Omega. After changing them I had a slight misfire, which was traced to a faulty plug lead, so I changed the leads, no more misfire.
When I examined the leads I came to the conclusion that they may never have been changed during the life of the car.  With this in mind I thought that the dis pack may also never have been changed. So I decided to change that as well (hence the title, "Was I mad", for changing something that wasn't causing any problems)
When I got the dispack out, no plasters needed (which I found easier with the removal of the wiper mechanism).   :y
This is what I found  :o
Interestingly it still worked.
Wasn't mad after all, it was a good decision, prevention is sometimes better than getting an earful from SWMBO when the car breaks down  ;D ;D ;D
The faster you go the bigger the grin.  Trade card user.
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Was I mad?
« Reply #1 on: 31 March 2008, 16:22:02 »
Looks like you've done the right thing :y
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
Re: Was I mad?
« Reply #2 on: 31 March 2008, 16:22:03 »
Mad no definitely not ..... its called preventitive maintenance.
It was just bad luck about the leads
best wishes
Simon.
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
Re: Was I mad?
« Reply #3 on: 31 March 2008, 16:22:52 »
i am very much a prevention person , for that exact reason!  :y
Re: Was I mad?
« Reply #4 on: 31 March 2008, 16:28:21 »
I dont think it would have been long before the Dis pack started to play up.
Re: Was I mad?
« Reply #5 on: 31 March 2008, 17:42:57 »
equally it could have lasted for months or years . . You cannot tell . . I had one like this on my elite once but never any trouble.
Re: Was I mad?
« Reply #6 on: 31 March 2008, 17:48:56 »
It depends on many things.
The bottom line is that the spark voltage would be lower as a result of the above and this may well affect economy slightly, it could also affect engine response etc and you might not realise....until it drops onto 4 cylinders!
