Author Topic: Advice needed on killing a tree root .............  (Read 8094 times)
I_want_an_Omega
« on: 22 March 2012, 18:45:24 »
I have removed a mass of Ivy which was destroying part of a fence. Ive cut the root just above ground level - the root must be about 3 inch in diameter.
Whats the best way to kill it?
I dont have ay used engine oil, but have heard that parafin or Jeyes fluid poured down a hole drilled in the stump should do the trick.
Thanks
Re: Advice needed on killing a tree root .............
« Reply #1 on: 22 March 2012, 18:52:44 »
Diesel does the job well :y
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #2 on: 22 March 2012, 18:55:12 »
drilling holes in it and push bit of copper tube into holes, the reaction to the copper kills it and also not as illiegal as tipping fluids around your garden to get into watercourse
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
Andys VXR
  • cambridgeshire
    • 3.2 Special
« Reply #3 on: 22 March 2012, 19:22:24 »
Yep as above bang some copper pipe into it does the trick lovely.
b4ndit
« Reply #4 on: 22 March 2012, 19:36:52 »
yep as previous two posts some copper nails/pipe will do the trick :y
martin42
« Reply #5 on: 22 March 2012, 19:42:25 »
got plenty of copper nails here lol  :D
Andys VXR
  • cambridgeshire
    • 3.2 Special
« Reply #6 on: 22 March 2012, 19:43:31 »
Hang on if its only 3 inchs round cant you dig around the base and cut roots a lump of copper pipe will be 15 or 22mm you will only need one bit.  ;D :y :y
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #7 on: 22 March 2012, 20:58:02 »
dont do what i did years ago with a cherry tree root,i set fire to it and when it was a blaze i suddenly remembered the gas board ran a gas pipe underneath it  ;D ;D
Andys VXR
  • cambridgeshire
    • 3.2 Special
« Reply #8 on: 22 March 2012, 21:07:41 »
So that was the big mushroom cloud i saw when i was on holiday down there.   ;D :D ;D :D :y
I_want_an_Omega
« Reply #9 on: 22 March 2012, 21:47:01 »
Ok, so if I drill a 16mm hole as deep as possible and then drive in a length of 15mm copper pipe that should do the trick? Should be able to get about 3 inches or so in .....
« Reply #10 on: 22 March 2012, 21:59:49 »
 :o :o :o ??? :) ;)
noel
  • frome somerset
« Reply #11 on: 22 March 2012, 22:35:03 »
never run so fast to get water ;D ;D
Andys VXR
  • cambridgeshire
    • 3.2 Special
« Reply #12 on: 22 March 2012, 23:36:13 »
Drill 15mm hole bang it in tight
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #13 on: 23 March 2012, 00:29:38 »
And how much copper pipe?  ;) ;D ;D ;D ;D
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #14 on: 23 March 2012, 01:10:45 »
Semtex'll sort it!
