Author Topic: fitting CD changer to E46 BMW  (Read 7328 times)
Big_Al
« on: 24 March 2012, 07:33:04 »
hi all,
              thought i would try here first if thats OK ::)
Daughter has just got herself a 2001 series 3  E46   2.0 SE diesel.   It has the "business" model steering wheel controlled radio / tape player which works fine.  She would like a CD player though.
Looking through the manuals & handbooks it says that the radio /tape player is " ready prepared to accept a BMW 6 CD changer & upgrading is simple"
My question is is it just the case of buying the changer & mounting bracket etc. to fit in boot & just plug in & play ?  :-\ :-\ :-\ :-\
Bet it's not that simple :( :( :( :(
TIA . . . .        Al   :y :y :y :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: fitting CD changer to E46 BMW
« Reply #1 on: 24 March 2012, 08:32:48 »
hi all,
Don't see why not tbh
« Reply #2 on: 24 March 2012, 09:19:48 »
If its got CD changer prep then all you have to do is plug the CD changer in and it'll work :y As it's an SE and not an ES it should have a CD player or changer I would've thought.
« Last Edit: 24 March 2012, 09:21:47 by Del Boy »
Big_Al
« Reply #3 on: 24 March 2012, 10:49:47 »
Hi Del , I know bugger all about BM's  :-[ :-[ so big learning curve for me here. Def a 320D SE Will check out boot area when she comes back , in case there is a changer in there already.  Only got car 5pm last night ,so gotta have a good look round it find out how things work :-[ :-[ :-[
Tried to get her to have a VX but not enough street cred for her with one of those apparently ;D ;D ;D
thanks mate regards, Al
Big_Al
« Reply #4 on: 24 March 2012, 12:11:01 »
Checked out boot area .  CD changer should go to left side on the tourer I presume behind carpeted cover where the warning triangle is stored.
Brackets are there along with 2 small loom connector blocks . . . so presume its had one in its early life but gone now . so should just be a plug in job I hope .    Plenty for sale on the bay of fleas .
Other jobs & faults  so far. . . .  1.        no blower at all      hopefully " porcupine resistor thingy"
2.     rear wiper & washer not working.
If anyone has any knowledge or experience of these items  any correspondance wil be greatly appriciated.   thanks
the alarming man
  • medway kent
    • disco V8
« Reply #5 on: 24 March 2012, 18:43:50 »
Hi Al check cabling that goes through to tailgate as it becomes brittle and breaks....hence no wipes/washers.... :y
I_want_an_Omega
« Reply #6 on: 24 March 2012, 19:40:11 »
ISTR recall that although the radio unit is chager compatible that the wiring to the back was an option - albiet for anout £35 or so.
If its there then it will plug straight in  :y, if not then try one of the BM forums as I'm sure this has come up many times before.
HTH
Big_Al
« Reply #7 on: 25 March 2012, 14:26:19 »
Hi mark,   Thought I'd found the simple answer to the rear wash /wipe problem  . . . NO fuse  ::) ::) ::)   fitted a 20A as stated & hey presto all working  ::)
BUT . . . with that fuse in   the front front wipers & washers don't work :o :o :o :o :o :o    taken the rear fuse out for time being till got a bit more time  :-\ :-\
Big_Al
« Reply #8 on: 25 March 2012, 14:28:45 »
HTH
Hi Robert  , thanks for reply .   There are 2 wiring connectors there & also the bracket to fit the changer to  - so presume it has had one fitted previously :y
the alarming man
  • medway kent
    • disco V8
« Reply #9 on: 25 March 2012, 21:00:58 »
Al i would check the wiring on the tailgate...as a friend of mine who is a auto electricain nearly sent one of  his customers (essex plod) 330 d up in smoke because of a short on  the rear tailgate and iirc that had a problem like you posted..  :y
Big_Al
« Reply #10 on: 26 March 2012, 18:48:32 »
Will do Boss ;D ;D ;D ;D    I'll  check it out ASAP  :y :y :y
