Author Topic: Near Disaster !!!  (Read 5392 times)
Zuffenhausen
  • Telford, Shrops.
    • 2000 2.5TD CD Estate
    • Walks and Waggy Tails
Near Disaster !!!
« on: 24 March 2012, 18:06:13 »
Just changed the windscreen washer pump - all good works fine  :)
Suddenly plumes of white smoke billowing out from under the bonnet from offside rear of the engine bay and alarm sounding a constant tone  :o
Whilst I disconnected the battery a neighbour came over with a fire extinguisher.
The source was between the servo and the wing right under thw winscreen scuttle, what is in there that has got too hot?
Re: Near Disaster !!!
« Reply #1 on: 24 March 2012, 18:12:00 »
Powersounder batteries leaking causing self-combustion.
« Reply #2 on: 24 March 2012, 18:13:31 »
My guess is the power sounder has just given up the ghost ... not unknown for these to catch fire ... remove it in the interim.
http://www.omegaowners.com/forum/index.php?topic=90675.0
HTH
« Reply #3 on: 24 March 2012, 18:30:50 »
What they said /\
It has it's own power, remove ASAP. Bit late now though, but to avoid any further risk...
Zuffenhausen
  • Telford, Shrops.
« Reply #4 on: 24 March 2012, 18:46:37 »
Correct! Burnt out at the connection - power sounder and connector US
Will the car run OK without the power sounder in place?
« Reply #5 on: 24 March 2012, 18:47:15 »
« Reply #6 on: 24 March 2012, 18:49:14 »
Yep, will be fine.
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #7 on: 24 March 2012, 19:02:18 »
just make sure no wires melted or youll have bigger fire next time round
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
Zuffenhausen
  • Telford, Shrops.
« Reply #8 on: 24 March 2012, 19:29:53 »
Wires look Ok
Off to the local breakers 2moro for a unit & about 6" of wire with the connector.
« Reply #9 on: 24 March 2012, 19:31:09 »
Wires look Ok
Bad idea, if replacing the PS, go new.
Zuffenhausen
  • Telford, Shrops.
« Reply #10 on: 24 March 2012, 19:39:14 »
Why new? Whats wrong with SH?
How much are they new?
adey2
« Reply #11 on: 24 March 2012, 19:40:48 »
dont know how old it is and could be on verge of self combusting itself
« Reply #12 on: 24 March 2012, 19:43:00 »
As Adey says.
Pricewise around the £65 mark, be advised a few different part numbers so check yours first
adey2
« Reply #13 on: 24 March 2012, 19:44:41 »
i got my new one off one of the dealers who sell off old stock for 30 quid off the bay, brand new in box
« Reply #14 on: 24 March 2012, 21:03:37 »
Yep, all of the original ones are failing, so pointless getting 2nd hand.
I'd also sorry about one that'd been on the shelf too long, as the age of the batteries is what matters. Check the date of manufacture on the back.
If you can cut open the old one and take some photographs of the damage I'd be interested. I've been trying to understand the exact failure mode of these...
