Pages: 1 2 [3]  All   Go Down
Author Topic: Falken tyres fitted all round.  (Read 7632 times)
Re: Falken tyres fitted all round.
« Reply #30 on: 28 March 2012, 14:38:44 »
And I bet you haven't used it much :P
Seriously, it would be good to compare to the 912, although the 452 I've driven on an Omega were shite, but the shagged suspension might have made it worse...   ...or better ;D
(Tunnie, your old heap was on 452s for a while?)
452's on rear 912's on front, still there, 35k later  :)
On 2.2, brilliant tyres. 912 had longer life, but they were on front not back. If/when the 2.2 is pressed into service again, I'd fit them again  :)
« Reply #31 on: 28 March 2012, 16:16:08 »
;D they do seem manageable at lower speeds, and less... Enthusiastic driving in corners may help them wear with a flater profile.
Absolute worst combination would be Elite suspension, press on driving style, 912....which last longer, there by allowing body roll and hence camber deflection on the front to wear the tyre more on the edges. The longer the tyre is on there the more rounded the tyre profile becomes and the more it wants to roll off high points and undulations in the road. It's like it deflects around bumps, rather than riding over them.
I'd be interested to see what construction techniques tyre manufacturers use to achieve thier various tyre characteristics.
Needless to say, high speed runs, on my private test track, are extremely hairy with these tyres fitted. A condition that appeared instantly once fitted, and no doubt will vanish again once sc3 or any other tyre, goes back on.
On the other hand Mr Daisy probably won't notice the instability, and appreciate the quitness and comfort alot more. ;) ( as said I do miss certain aspects of Falkens personally, just dont tell anyone I said so ;D. )
« Reply #32 on: 28 March 2012, 16:20:54 »
Must get you to come round and drive mine with the Neuton's on some time, Chris .. you might change your opinion on Falkens then  ;D Either that or Falkens are really, really, REALLY bad..
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #33 on: 28 March 2012, 17:59:19 »
Sounds like i got off lightly with not getting the Neutons. Seem to remember we were both looking at these at the same time but i didn't realise they fitted them round the M25 till after i had Kuhmos fitted. Are they really that bad?
Those are my principles, if you don't like them I have others.
« Reply #34 on: 28 March 2012, 18:24:18 »
I wouldn't say they're really that bad as such .. they wander more than the winter tyres did, but the winter tyres are significantly narrower and higher profile (195/60 vs. 235/45) so it's not a great comparison really - I suspect the extra width is always going to make them more prone to following the ruts in the road.
The car could almost certainly use an alignment, too :-[
« Reply #35 on: 28 March 2012, 21:23:11 »
If you want noisy the Bridgestones on the Ibiza are deafening. Bloody hard to.
Indeed they are. Potenza 001 on mine when I got it. Thought they where shite tbh.
potenza 001 is no shit, nothing can corner like them even your sc3.. ;D
Having driven chrisgixer's car on Potenzas, I can confirm they were quite poor.  Can't remember how worn they were though, but happy to let go with little provocation in the dry.
Pages: 1 2 [3]  All   Go Up
