Author Topic: Glow plug relay problem  (Read 12111 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Glow plug relay problem
« Reply #15 on: 26 March 2012, 18:43:03 »
From underneath theres 2 small clips either side holding the cover on, get a small blade / knife in either side and cover should come off.
Do it to relay that you have just been measuring.
Agemo
  • Cleethorpes
  • Insignia
« Reply #16 on: 26 March 2012, 18:46:07 »
OK, cover off. The contacts are lovely. This is the one that is off the car, I will change it over & look at the other one
zirk
  • Epping Forest
« Reply #17 on: 26 March 2012, 18:49:57 »
Did you measure each GP resistance to neg, 1 to 2 ohms each.
Sound like its dropping from 12 to 3.2 v through the relay to me, does the relay measure open / short when you press the contacts together.
Agemo
  • Cleethorpes
  • Insignia
« Reply #18 on: 26 March 2012, 18:54:21 »
OK, I have put the cover back on the relay, and refitted it. It still reads 3.5 volts, IGN on or off. Not measured ohms at GPs yet.
Agemo
  • Cleethorpes
  • Insignia
« Reply #19 on: 26 March 2012, 18:57:44 »
Readings have been identical with both relays. You will have to talk me through the "does the relay measure open / short when you press the contacts together."
I assume I fit the relay, then test while closing the points at the same time? (Like rubbing head & patting belly)  :-\
zirk
  • Epping Forest
« Reply #20 on: 26 March 2012, 18:58:24 »
We are measuring the right pins here, as you pull the top plug off theres 6 thick pins that are all connected to together?
Agemo
  • Cleethorpes
  • Insignia
« Reply #21 on: 26 March 2012, 19:02:37 »
OK, I have the relay fitted, meter between earth and the six pins to the GPs, it is reading 3.5 volts. When I close the points, it goes up to 13 volts.
On turning the IGN on, something goes clunk in the triangular box.
« Last Edit: 26 March 2012, 19:11:39 by Agemo »
zirk
  • Epping Forest
« Reply #22 on: 26 March 2012, 19:13:15 »
Its the 3.5 V bit thats throwing me now, been a couple of years since I played with these TD's, in theory from memory it goes battery connects directly to relay (via small red cable and 8mm nut, so 12 volts all the time on one side of the relay contact, which simply switches the GP's on off. not convinced where the 3.5v is coming from on the GP side (assuming the relay contacts are not arced or stuck together.
zirk
  • Epping Forest
« Reply #23 on: 26 March 2012, 19:15:17 »
Whilst you where doing tests, was the inlet manifold warm or hot?
Agemo
  • Cleethorpes
  • Insignia
« Reply #24 on: 26 March 2012, 19:16:57 »
Your memory seems spot on. Red wire looks like it feeds 12v, the contacts gives or stops current to the GPs. The contacts are like new. Not sure how I get 3.5 volts either.
This is the original relay, the one I tested & stripped, it worked perfectly this morning.
« Last Edit: 26 March 2012, 19:22:36 by Agemo »
Agemo
  • Cleethorpes
  • Insignia
« Reply #25 on: 26 March 2012, 19:17:43 »
Cold, engine not been run for seven hours.
zirk
  • Epping Forest
« Reply #26 on: 26 March 2012, 19:21:51 »
Diss the plug again, measure each GP (+volts) and ground all should be 0v.
Did you manage to measure each GP resistance yet (1 to 2 Ohms).
Agemo
  • Cleethorpes
  • Insignia
« Reply #27 on: 26 March 2012, 19:24:22 »
Didn't quite understand your banter there, sorry, do you mean measure at the six pins?
No, not yet, will do it now.
zirk
  • Epping Forest
« Reply #28 on: 26 March 2012, 19:30:54 »
No sorry, probably me thinking out loud, measure each lead that connects to each GP, trying to work out if theres any stray voltage floating around somewhere.
Agemo
  • Cleethorpes
  • Insignia
« Reply #29 on: 26 March 2012, 19:35:11 »
OK mate, just trying to keep up with you. I have checked the lead, at two of the GPs, zero volts. This was with contacts open of course.
Pages: 1 [2] 3 4  All   Go Up
