Author Topic: whats that in my boot  (Read 4318 times)
marrus69
  • bracknell
    • 52 mv6 3.2
« on: 26 March 2012, 18:07:12 »
Re: whats that in my boot
« Reply #1 on: 26 March 2012, 18:12:43 »
A present for some chavs ;D ;D
Bucko
  • Newark notts
    • 53 2.2 omega
« Reply #2 on: 26 March 2012, 18:26:45 »
There I was thinking the sound system
In the omega sounds great  ;)
Does it make your door mirrors shake,
Looks a nice Fit  :y
« Reply #3 on: 26 March 2012, 19:03:32 »
Its a new style gas conversion tank  :P
Bet it booms well  8)
x25dt
  • Portugal
« Reply #4 on: 26 March 2012, 19:24:59 »
Looks god mate :y
marrus69
  • bracknell
    • 52 mv6 3.2
« Reply #5 on: 26 March 2012, 21:07:28 »
looks good but one problem was fitted by ice experts remember its running of the stero thats in the car,thay tapped of the front right and left speaker,which just dont supply enough power to the 800w amp fitted to base box when you crank up the speakers in the car distort,think im going to have a better stero fitted and loose sat nav,
« Reply #6 on: 26 March 2012, 21:53:50 »
So, the ICE "experts" connected that up to your Bose system ?  :-X :o ::)
twiglet
  • Norwich, Norfolk
« Reply #7 on: 27 March 2012, 08:51:12 »
Probably not a Bose system (as not standard on the MV6's) but the NCD2013/5 headunits don't have dedicated pre-outs to run amps.  Therefore, the only options are to take the signal from the speaker outputs, as in this case, which is never going to produce a decent sound, or to rip the H/U out and replace it with modern H/U.  This will solve the sound quality issue, but youy will then lose some of the built in functionality of the standard system.  It's a trade off that has been discussed to death here.
My view, the best system for an Omega is the an NCDC2015 with CID, Telematics and Bose.  It's the best compromise in an aging car.  If that's not good enough, don't change the system, replace the car!  :y
MrMoffat
  • Lincs East Coast
  • C5CEA2C4801C
    • 2003 3.2 Police Special
« Reply #8 on: 27 March 2012, 09:00:55 »
I did consider this mod  :D but then decided on a pair of hearing aids  ::)  ;D free with the NHS  :y
Mike.
« Reply #9 on: 27 March 2012, 23:54:56 »
I never knew you could have NCDC with satnav which wasnt Bose enabled and connected to a Bose system. :-\
« Reply #10 on: 28 March 2012, 01:08:38 »
Rip that poxy thing out, that's where the LPG tank goes. ;D
Retro fit Bose (if possible) there will be no distortion then. Oh no! Flat out no problem.
