Author Topic: Extended cranking before firing..  (Read 1574 times)
« on: 27 March 2012, 19:21:03 »
I suspect I know what this is likely to be, but..
A couple of times recently - both when the car was cold - I've noticed it takes several cranks longer than normal to fire. In fact, before driving home tonight it took long enough that I thought it wasn't going to fire at all.. a good 4-5 seconds of cranking. Runs fine apart from that (and the stink of oil  :-[) although the idle is perhaps a little more 'wavery' than it was when I bought the car.
Prime suspect the crank position sensor?
Re: Extended cranking before firing..
« Reply #1 on: 27 March 2012, 20:05:47 »
 :y :y :y
« Reply #2 on: 27 March 2012, 20:08:30 »
:y :y :y
Thought as much..
Would be dead easy to change if it weren't for the big giant Jag in the way of using the pit.. ;D
« Reply #3 on: 27 March 2012, 20:23:48 »
:y :y :y
Thought as much..
What are your plans for the V12, Aaron?
« Reply #4 on: 27 March 2012, 20:32:52 »
It's in bits .. the front suspension/hubs and rear axle will be going in the kit car, the interior should make a nice three piece suite for the livingroom, engine will probably make a coffee table for someone and the rest will likely end up crushed.. which is probably for the best given the amount of rot in the firewall!
« Reply #5 on: 28 March 2012, 10:50:55 »
Hm, doing the extended cranking thing most of the time now - no engine light, of course (haven't checked for pending but not present codes, yet).. best I get that crank sensor ordered before it fails and lets me down somewhere!
Still seems to run fine once it's caught and fired, though.
« Reply #6 on: 28 March 2012, 10:59:01 »
Got the same problem myself. Keep asking the OOFer who I loaned my spare crank sensor many months ago to return it,but many broken promises and excuses later,still no sign of it. Thats what you get for helping people I suppose. We live and learn. >:(
« Reply #7 on: 28 March 2012, 11:42:46 »
Live and learn indeed, Albs!
Just called Andy and ordered one for myself, £40-something plus VAT so not too bad. Guess I know what I'll be doing on Saturday morning :)
Page created in 0.026 seconds with 20 queries.
