Author Topic: Heater problems  (Read 4877 times)
TNTom
Heater problems
« on: 27 March 2012, 22:19:15 »
Hi chaps, after posting a while back about getting an omega I finally made the splash and picked up a t reg 2.5 v6 elite, will post some pics ect in the newbie area when I get to a pc. Only problem with the car is that the heater does not blow hot at all. The car had a new matrix fitted a few years ago. So this should possibly rule out that problem?
What should I check/expect the worse cost wise ect
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Heater problems
« Reply #1 on: 28 March 2012, 09:03:20 »
would try a flush out, failing that may be an air lock in the systerm. what dose the engine temp run at.
Solar charger fitted.
If not Broke dont fix it..
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
Re: Heater problems
« Reply #2 on: 28 March 2012, 10:38:35 »
I'd be checking all the vacuum pipes from the HBV and under the dash.
TNTom
Re: Heater problems
« Reply #3 on: 28 March 2012, 13:36:11 »
Thanks chaps, i'm not so clued up on cars ect, where about are these pipes located?
doz
  • Southampton
Re: Heater problems
« Reply #4 on: 28 March 2012, 13:50:20 »
Start by looking under the bonnet offside of the engine at the bulkhead. Your see lot's of small vacuum pipes. Just check there all connected. Your see that some go in to the cabin through the bulkhead. Next thing to do is get the Karma Sutra manual out find a good position which allows you to get your head under the dash and look up at above the peddles. Torch required and your need to remove the panel to see. If that all seems ok then the next thing to check is the HBV
TNTom
Re: Heater problems
« Reply #5 on: 28 March 2012, 15:08:41 »
Ill have a check, HBV is heater somthing valve right?
Re: Heater problems
« Reply #6 on: 28 March 2012, 15:41:56 »
Heater By-pass Valve.
It lives behind the driver's side of the engine, looks a little like Capt Kirk's Star Ship Enterprise.  ;) there is a guide somewhere here, but you remove the plastic scuttle under the wiper motor to gain access.  :y
TNTom
Re: Heater problems
« Reply #7 on: 29 March 2012, 01:10:19 »
any chance someone could link me to the guide, pretty please :)
gstylebaby
  • stockport
Re: Heater problems
« Reply #8 on: 29 March 2012, 02:17:39 »
TNTom
Re: Heater problems
« Reply #9 on: 31 March 2012, 00:36:39 »
So because im useless im offering beer tokens plus to someone who would fancy trying to figure out what is up with the heater. Im based in slough, so anywhere around berk,buks,surrey would be good, happy to travel if need be.
TNTom
Re: Heater problems
« Reply #10 on: 31 March 2012, 18:54:36 »
anybody?? :-\
TNTom
Re: Heater problems
« Reply #11 on: 07 April 2012, 18:11:32 »
sorry chaps, what is the precise job of the HBV?
Re: Heater problems
« Reply #12 on: 07 April 2012, 18:13:18 »
puts hot water through the heater matrix as required.  :y
TNTom
Re: Heater problems
« Reply #13 on: 07 April 2012, 18:20:05 »
One last question, as far as i know its not leaking, how would i check that its not working, apart from the obvious no warm air coming through the heater.
Re: Heater problems
« Reply #14 on: 07 April 2012, 18:27:52 »
HBV generaly fail by leaking water.  Not sure which way the HBV works, but the small vacuum connection on top is what moves the diaphragm inside ie vac on/off = heat/no heat ............ but as I say I don't know which way round.  :-\
Have you checked for air locks in the system?
