Author Topic: Blanking off EGR??  (Read 5796 times)
mark3
  • Rainahm Village~Essex
Blanking off EGR??
« on: 28 March 2012, 14:14:10 »
Has anyone blanked of the EGR on there 2.5 V6??
My EGR valve has started to blow, it always did a bit from cold but now its doing it quite badly when hot too so as a temp cure i removed the valve and made up a gasket from zinc but with no holes so it has effectively blanked of the EGR... not sure what to expect as far as performance or fuel consumption goes though, the engine certainly sounds a lot crisper when reved now but as its up on stands waiting for a new wishbone i not driven it yet..
Tomorrow will tell as i have a job the other side of the M5 near Kidderminster and one in Reading & as i live in Essex i have loads of miles to do...
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
Re: Blanking off EGR??
« Reply #1 on: 28 March 2012, 15:00:44 »
I wouldn't mind finding this out where you blanking it off ar bottom or at the plenium  :y
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #2 on: 28 March 2012, 15:42:11 »
I blanked mine off years ago and no problems so far.
Elite_L0ver
  • On too Omega #2
« Reply #3 on: 28 March 2012, 18:33:17 »
Which part ;D
hotel21
  • The Kingdom of Fife
« Reply #4 on: 28 March 2012, 18:36:03 »
Which part ;D
Between EGR and plenum.  Leave unit, electrics etc in place else it throws a fault code as I recall.
« Reply #5 on: 28 March 2012, 18:50:27 »
Interesting , i was wondering if i could remove mine too  :y
mark3
« Reply #6 on: 28 March 2012, 21:18:01 »
On my V6 all i did was remove the two torx bolts to get the egr valve off, i then made up a gasket out of zinc with only holes for the bolts then bolted it back on
Im guessing it wont be too long before the hot gasses burn through the zin though, lol
if you look at the edge of the stainless steel flap you can see where it was blowing from, it allways did a little bit but only from cold start but it got quite bad even when engine was fully hot.
amba
  • Medway towns
    • German V6
« Reply #7 on: 28 March 2012, 21:35:49 »
Mines been blanked off now for the past 60k and had no problems. :y
« Reply #8 on: 28 March 2012, 21:48:10 »
Were the torx easy to get out , mine look pretty rusty so dont want to be snapping them off  :-\
mark3
« Reply #9 on: 28 March 2012, 22:07:29 »
Yes, once cracked of they spun out lovely, i was quite surprised lol
« Reply #10 on: 28 March 2012, 22:14:36 »
What if any are the benefits to blanking off this ?
Zippy2012
  • Worcester uk
    • 99,3.0 MV6 Est Ex Police
« Reply #11 on: 28 March 2012, 22:14:54 »
you will only be 10miles from me!  :y
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« Reply #12 on: 29 March 2012, 12:16:00 »
Isn't there a 'How To' for this?  If not, maybe Mark3 could knock one together for the aid of the site?  8)
Your not far from me Mark, have seen your sign written car in various places now...  :y
mark3
« Reply #13 on: 30 March 2012, 20:45:16 »
Well, Thursday the Omega drove beautifully, seemed much more responsive to small throttle changes at speed and pull away from standstill seems better too. i drove most the journey in sport mode, i filled up the night before and got 200 miles out of 2/3rds of a tank before putting in another £50 worth.
So it seems the fuel consumption is as it always was, over 300 miles per tank which considering the weight i always carry and my heavy right foot im pleased with.
Oh and i was in Bewdley, near Hartlebury and Kidderminster, went past a pub called the Mitre oak which i been to before when i stayed in the travel lodge up the road.
If i get a chance il pull the EGR valve off again and use as a template so i can make up some more zinc gasket which when fitted blank of the EGR, this will be on a 2.5 V6 though as thats all i got to work from, lol, then il put up a guide to blanking your EGR but it prolly isnt needed as its so simple to do.
« Last Edit: 30 March 2012, 20:50:36 by mark3 »
P6UL K
  • Dartford, Kent
« Reply #14 on: 31 March 2012, 04:20:57 »
I don't think mine has an EGR? Not in the area yours is if i do have one :-\
