Author Topic: central locking problem  (Read 2714 times)
ZacVegas
  • Southampton
  • Beer, nothing else matters
    • 2000 'X' Omega 2.5CD
« on: 28 March 2012, 16:12:36 »
When I open the car with the remote it locks itself again, to get in the car I have to open the door very quickly after pressing the button.Any helpwould be appreciated :-\
tango
  • brum
Re: central locking problem
« Reply #1 on: 28 March 2012, 16:31:10 »
if you open drivers door with key
is it difficult to turn if so it could be the motor
ZacVegas
  • Southampton
« Reply #2 on: 28 March 2012, 17:26:56 »
Put the key in and turned it, feels ok, not stiff at all
« Reply #3 on: 28 March 2012, 18:54:12 »
Is the driver's door unlocking OK on the motor,a nd the button popping up before it locks again?
Could be driver's door central locking motor, or possibly the contacts on the key lock on the driver's door.
Something is commanding the ECU to lock it again. ;)
ZacVegas
  • Southampton
« Reply #4 on: 28 March 2012, 19:04:57 »
The drivers door unlocks fine and yes the door button pops up before dropping again as the doors relock themselves
ZacVegas
  • Southampton
« Reply #5 on: 29 March 2012, 15:33:57 »
When I lock the car using the key the central locking works fine, its only when I use the remote. Could this still be the drivers motor?
« Reply #6 on: 29 March 2012, 16:23:19 »
I'm not sure, is the honest answer.  ;)
I know that, if the central locking motor on the driver's door fails (as in won't lock the door at all), when you lock the door with the fob, it immediately senses that the drivers door is unlocked and unlocks the rest again.
It senses that the door is unlocked using a microswitch in the locking motor.
So, if that switch were to fail, I would expect similar symptoms as the ECU would detect that the door hadn't locked even if the button had physically moved.
I think that's the most likely cause.
ZacVegas
  • Southampton
« Reply #7 on: 29 March 2012, 16:57:23 »
Thanks for your help Kevin I'll get a Motor and see what happens :y
