Author Topic: (Ford) Audio - question for Dave DND  (Read 2215 times)
I_want_an_Omega
« on: 28 March 2012, 18:36:40 »
Hi Dave,
Have you any experience of the Ford 6006E unit having a flashing LCD display. The unit works fine - but the display flashes on/off every second or so.
It's defo a fault with the display itself as I swapped it with a spare I have.
Many thanks - Rob
martin42
Re: (Ford) Audio - question for Dave DND
« Reply #1 on: 28 March 2012, 21:33:04 »
clean the contacts on the removable panel,surprised its still working not the best unit from ford
I_want_an_Omega
« Reply #2 on: 28 March 2012, 21:36:34 »
thanks ............
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 29 March 2012, 09:16:16 »
Usually a dry joint on the fascia -
LCD panel is often plugged into a socket on the main board - remove and refit a couple of times and problem may well go away.
If not, and you have a Visteon version, then the "blue" or "green" paint on circuit tracks may be starting to bio-degrade on the fascia - and that is going to be a "send to me" jobbie, not a self fix.
Radio & Decoding Technician
www.dndservices.co.uk
