Author Topic: L200 Pro's & Con's  (Read 1896 times)
Dr_X
L200 Pro's & Con's
« on: 29 March 2012, 02:53:17 »
Been snowed in the last few years and swmbo is not too happy about driving in the ice and snow since she removed the front end of her mig with a hedge a few years back, so I was thinking about an L200 Warrior.
All I know about them is they look pretty cool and they either run forever or go bang, so if any of you guys can point me in the right direction with what to look out for that would be great.......
Thinking 05/06 with 40-50k miles???
cheers
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: L200 Pro's & Con's
« Reply #1 on: 29 March 2012, 08:15:08 »
Do you suffer from a bad back ?  ;)
Omegatoy
  • UK
« Reply #2 on: 29 March 2012, 08:49:18 »
Ze had one for 2 years, and would still have it if the thieving scrotes hadnt stolen it and burnt it out!!
brilliant piece of kit drives like a car, engine as you say can run forever or go bang, reason they go bang?
oil changes are a must every 4.5k miles!! no matter what anyone tells you, read the engine specs and it states there, dealer will tell you oh yes 10k oil changes no problem, well it is!!air filter max 20k between changes, transfer box 50k gearbox i did once a year,,other cpommon reason for bangs is a lot of people chip them, dont!! turn the pump up slighty and adjust the wastegate if you want a fraction, it dont need any more, chipping drastically shrtens the life of this old design engine!! newer did is not much better longevity wise!!
clutch can be a bit weak if ridden, clonks from suspension quite common, ride better with half a ton in the back,
go to Milners and get a polybush kit, for rear springs roll bar, and all suspension joints etc, it then drives like a dream completely silent,handls much better as well, can be heavy on the front brakes depending how driven, rear shocks get tired, eveything is easy to work on,
get it!!
Dr_X
« Reply #3 on: 29 March 2012, 08:57:38 »
Thanks omegatoy  :y
No...why?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 29 March 2012, 09:40:28 »
Thanks omegatoy  :y
No...why?
Knew a sparky who had one for work a few years back.
He said he prefared the ride of his old landrover to it because it did his back in  :(
He now drives a boarded out Toyota Rav 4 for work
Dr_X
« Reply #5 on: 29 March 2012, 09:53:15 »
Oh I see.....don't think that will be a problem but my old K5 blazer used to make my wifes t*ts hurt from all the bouncing around.......
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #6 on: 29 March 2012, 10:55:38 »
Best you employ a driver so you can help her by giveing them a little support  ;) ;D ;D
« Reply #7 on: 29 March 2012, 11:11:25 »
 ;D
« Reply #8 on: 29 March 2012, 14:30:15 »
Sounds like completely inadequate suspension to me...
Not necessarily on the vehicle.. ;)
