Author Topic: rear seatbelt  (Read 3324 times)
omegatel
  • newport,s.wales
    • omega 2.6cdx estate
rear seatbelt
« on: 29 March 2012, 21:01:23 »
mot today,passed on everything except centre seatbelt,catch on seat faulty and not activating the belt release.garage trying to repair but can't get it back in,afraid they might break it,anyone had this problem and fixed it ,please
Re: rear seatbelt
« Reply #1 on: 29 March 2012, 21:43:55 »
Not sure what you mean. Is the seat belt not able to be pulled out? Or it's not feeding back in? If not pulled out, it's connected to the button on the top of the seat that you press to lay the back down for loading etc. I used to have problems with my Astra estate, I used have to make sure that before laying the back down, I released some belt otherwise, when it was lifted back up the belt would lock up & not release. To get it to feed back in I'd unbolt the belt form under the seat base to give some slack, it would work OK then.
hotel21
  • The Kingdom of Fife
Re: rear seatbelt
« Reply #2 on: 29 March 2012, 23:30:59 »
sounds like the static buckle is goosed.  Easy enough to get a replacement from a breaker for a couple of squids and 10 mins with a socket set to remove/replace....   :)
omegatel
  • newport,s.wales
Re: rear seatbelt
« Reply #3 on: 30 March 2012, 20:47:10 »
Sorry Andy,didn't explain it right,can't pull it out,think linkage is damaged between belt and catch,garage priced new about£180 and got to come from germany,got car back and will have a go myself over weekend,failing that will phone around scrappies.cheers for imfo,Terry
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: rear seatbelt
« Reply #4 on: 30 March 2012, 21:32:01 »
got mine undone with some degreaser, kids sweets stuck in it..
Solar charger fitted.
If not Broke dont fix it..
omegatel
  • newport,s.wales
Re: rear seatbelt
« Reply #5 on: 30 March 2012, 22:10:30 »
That would be too easy,no think it's the linkage :y
Re: rear seatbelt
« Reply #6 on: 30 March 2012, 22:15:46 »
Try as I suggested then, and unbolt the belt from the floor under the seat to give more slack in the belt, it should allow the mechanism to be release the belt.  :-\
Re: rear seatbelt
« Reply #7 on: 30 March 2012, 23:15:33 »
There's a guide in the maintenance section written by yours truly :y
HTH Al :y
omegatel
  • newport,s.wales
Re: rear seatbelt
« Reply #8 on: 31 March 2012, 19:41:29 »
HTH Al :y
Cheers Al,but the belt works fine.Garage has failed to repair so stripped it myself and disconnected cable from locking mech and the belt is ok,just try to get lock working and should be good,thank,Terry
omegatel
  • newport,s.wales
Re: rear seatbelt
« Reply #9 on: 03 April 2012, 20:18:18 »
mot sorted,seatbelt working ok,thanks for any help off all,terry
