Author Topic: Best Way To Decant Fuel From Omega Estate  (Read 3833 times)
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« on: 30 March 2012, 17:22:01 »
Hiya fellas, as per title really. Due to the current fuel issues at garages, i've my work car (1.8 Mk3 Mondeo) with a full tank ready for next week, the wifes Mk3 Mondy at 3/4 full and Ollie (Omega) with a full tank.
Going down to Dorset this weekend and plan on doing about 350 miles total. Instead of joining a 45 minute queue for fuel, I was wondering if there is an easy & safe way to decant fuel from Ollie into a couple of 1 gallon containers so i can take it with me in the wifes car and top hers up in the process.
As per usual, any help/advice much appreciated fellas :y
Those are my principles, if you don't like them I have others.
Re: Best Way To Decant Fuel From Omega Estate
« Reply #1 on: 30 March 2012, 17:23:36 »
Don't bother.
1. It is dangerous
2. It is not neccessary - there is no strike and no fuel shortage.
3. Do not be a lemming - think for yourself.
« Reply #2 on: 30 March 2012, 17:29:26 »
Find a petrol station and fill up, simples.  :y
« Reply #3 on: 30 March 2012, 17:31:43 »
All valid points.. should you ever find yourself in a position of wanting to (mostly) drain a fuel tank in (relative) safety, however;
1) Disconnect the fuel feed in the engine bay, direct hose into a jerry can.
2) Bridge correct terminals on fuel pump relay.
3) Energise relay
4) De-enerise (or un-bridge terminals) when jerry can almost full.
That's how I drained the Jag a couple of weekends ago (prior to it being scrapped, before anyone says anything!) and several other cars destined for the scrappers before that.
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #4 on: 30 March 2012, 20:52:04 »
Cheers for that fellas :y
I know like most that there is no imminent strike but 2 out of our 3 local garages are dry. As Aaron wil know, most of Bracknell is dry literally due to, as mentioned, the "lemming" effect. Talking to the friends we are due to see in Dorset its pretty much the same down there, so with a 5 & a 7yr old in the car i need to make sure i get back. Its doesn't appear to be a case of just find a petrol station either....i could be wrong & have been many a time  ;D
Cheers for the step by step Aaron, much appreciated fella :y
« Reply #5 on: 30 March 2012, 20:53:40 »
It's not quite a step by step as I missed bits out like - have towel handy for the fuel that comes out when you disconnect the hose .. not to mention the location of said relay :) But you get the drift, I'm sure.
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #6 on: 30 March 2012, 21:02:03 »
Yeh i'm ok thanks Aaron. Found the terminals i need..... Cheers again fella :y
« Reply #7 on: 30 March 2012, 21:04:33 »
In addition, be aware that bridging the terminals on the fuel pump relay will cause a spark, which is a possible source of ignition. I would want the whole lot to be out in the open air, and I would have the spark, and myself, at the other end of the car to the fuel, personally, so jerry can at the rear.
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #8 on: 30 March 2012, 21:08:23 »
Cheers for that Kev.... thought the same! Already got a toggle switch with about 5M of tri rate 1.5mm sorted out :y  In the words of Captain Mainwaring "Don't Panic Pike"  ;D ;D
Cheers Kev  :y
« Reply #9 on: 30 March 2012, 21:09:32 »
Granted - try not to blow yourself up doing it ;)
On the MR2 the fuel pump (it was easiest to stick 12V on the pump directly) is inside the car while the hose is outside, so low risk.
The Jag, however, had the fuel hose on one side of the engine bay and the relay on the other. We were .. a little more careful.
Well .. there was an extinguisher nearby, anyway. :-X
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #10 on: 30 March 2012, 21:21:09 »
There is a woman in York you could ask  :-X :-X :-X
« Reply #11 on: 31 March 2012, 09:45:16 »
I've always done it using fuel line from inlet manifold into jerry can, and applying 12v to the pump relay.
Now I have a bit long bit of loom that plugs straigh into fuel pump, and drive it from a jumpstarter.
« Reply #12 on: 31 March 2012, 09:46:21 »
Then when you have it, take it in the kitchen, pour it over yourself, and light the gas hob...  ...seems to be all the rage nowadays ;D
« Reply #13 on: 31 March 2012, 12:24:26 »
 :y Surprising how fast you can empty a tank with just the fuel pump, isn't it.
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #14 on: 31 March 2012, 23:44:32 »
 :y Surprising how fast you can empty a BBQ garden with the fuel pump spraying it around, isn't it.
Fixed that for you.  ;) ;D ;D ;D ;D
