Author Topic: maff sensor ???  (Read 1732 times)
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
maff sensor ???
« on: 01 April 2012, 16:01:29 »
took wifey to work this morning with no problems, went to start the car 2 hours later and car started but immediately cut out, tried this 4 times same thing all the time, checked for codes doing pedal trick and with code reader but no codes present. >:(
After a bit of investigation i decided to disconnect the maff airflow sensor plug and it started and ran perfect,the car seems to have a little bit more get up and go 8).
Does this point to a faulty maff sensor  :-\  & if so can this be cleaned or just replace with a new one  :-\.
thanks in advance Noel.
Re: maff sensor ???
« Reply #1 on: 01 April 2012, 16:43:13 »
Yep mate faulty maf sensor - with it disconnected engine will run on a default map.
Don't try cleaning it - rarely successful - fit new/good used. :y
Re: maff sensor ???
« Reply #2 on: 01 April 2012, 17:32:18 »
On the other hand i've cleaned mine successfully several times now using Isopropylene Alcohol & a thin paint brush, so perhaps worth a try. Also worth checking the maf plug pushes firmly home and the contacts are clean? :y
noel
  • frome somerset
Re: maff sensor ???
« Reply #3 on: 01 April 2012, 18:04:53 »
will be fitting a new one  ;). Thanks for the reply :y
noel
  • frome somerset
Re: maff sensor ???
« Reply #4 on: 01 April 2012, 18:06:39 »
already checked the plug for security and cleanliness ;) thanks for the reply :y
