Author Topic: oil in the holes  (Read 5445 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
oil in the holes
« on: 02 April 2012, 14:46:22 »
just put new plugs im my 2.2 ....oil in every port...is it rocker cover gasket
Re: oil in the holes
« Reply #1 on: 02 April 2012, 14:48:22 »
Yes.And blocked breathers.
« Reply #2 on: 02 April 2012, 14:52:20 »
......and possible perished boots on the coilpack
Steve B
  • Leicestershire
« Reply #3 on: 02 April 2012, 16:50:58 »
do i do all of this tutorial to clean engine breather out
http://www.omegaowners.com/forum/index.php?topic=90528.0
« Reply #4 on: 02 April 2012, 17:56:26 »
Yep,then change the rocker gasket and change the oil and filter at intervals of no more than 5000 miles to prevent it recurring.
Also clean the breathers annually. :y
Steve B
  • Leicestershire
« Reply #5 on: 02 April 2012, 18:31:43 »
ok will do thanks albs;;
take it go to main dealer for parts
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #6 on: 02 April 2012, 18:33:46 »
best to use gm parts as you only want to do it once  :y
SteveAvfc.
    • Mv6 2.6 V6
« Reply #7 on: 03 April 2012, 18:40:18 »
Andy Clears will sort you out find his details in Recommended Suppliers   :y :y
Steve B
  • Leicestershire
« Reply #8 on: 02 May 2012, 22:39:47 »
done gasket   2 of them are split. do i need to replace
if so pattern or vx
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #9 on: 02 May 2012, 22:44:42 »
....And please wear goggles and gloves when using the carb cleaner. See my thread ''Blind Bear with now patchy fur''  :-[ ::) :D
RIP Paul Lovejoy
Steve B
  • Leicestershire
« Reply #10 on: 02 May 2012, 22:50:45 »
wot
Webby the Bear
  • Northampton
« Reply #11 on: 02 May 2012, 23:16:12 »
wot
lol i'm saying wear goggles cos if the carb cleaner sprays back in your eye like it did for me you'll be down eye casualty..... like me.
also, i got a load of it on my skin. fekkin' burns!!!!
HTH  :y
RIP Paul Lovejoy
Steve B
  • Leicestershire
« Reply #12 on: 02 May 2012, 23:19:43 »
i got it on my skin/fingers too..yes it hurts.. but i have no more spanner lights so im happy to spray it anywhere the wife tells me to;
Webby the Bear
  • Northampton
« Reply #13 on: 02 May 2012, 23:28:00 »
 :o :o :o :o :o well i suggest you definitely dont piss her off!!!  :D :D :D :D ;D ;D ;D ;D
RIP Paul Lovejoy
flyer 0712
« Reply #14 on: 02 May 2012, 23:30:14 »
Ref perished rubber boots on coil pack.....a kit of 4 boots..4springs and 4 rubber .o. rings can be bought from the dealer for less than £20..thats what i did and genuine cam cover gasket....job done properly then  :y
