Author Topic: broken spring  (Read 4682 times)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: broken spring
« Reply #15 on: 31 March 2008, 22:14:48 »
Think there all the same....
Buypartsby (sutton auto factors) do KYB ones at a good price although you might have to ring them.
Only take an hour tops to change.....dead easy job.
Really, thought they were different as most ads I've seen say not for self levelling.
Anyone with access to EPC care to look for the part no please?
(2000MY elite saloon facelift)
I can check it tomorrow for you with he old boy............
Cheers Mark. :y
TuBy's new whipping boy.
Re: broken spring
« Reply #16 on: 31 March 2008, 22:17:25 »
Looks like they are different!
Re: broken spring
« Reply #17 on: 31 March 2008, 22:38:59 »
 :o :o
That was with you doing it, normal folk should allow 3 hours  ;D
  • Online Online
Re: broken spring
« Reply #18 on: 31 March 2008, 23:57:06 »
Are Omega pattern springs progressive rate like the originals. I ask cos SWMBO's Astra G had 2 broken rear springs last year. The originals were progressive rate but as Vauxhall wanted more than I was prepared to spend on 2 springs I bought a pair of pattern springs from a motor factor. They were some thing like £30 but were NOT progressive rate.
hotel21
  • The Kingdom of Fife
Re: broken spring
« Reply #19 on: 01 April 2008, 00:01:52 »
I think the design of the springs - the pigs tail/taper spring construction - gives the progressive rate.  Aftermarket ones should do the same....
  • Online Online
Re: broken spring
« Reply #20 on: 01 April 2008, 00:05:13 »
Yes it does. The thin bits at the end bend esier than the fat bit in the middle. But as I say the pair I bought for her Astra were the same thickness through out. The distance she covers in a year, they are more than adequate, & will probably fair better on the speed ramps as she hits them.  :-?
« Last Edit: 01 April 2008, 00:05:38 by Andy_B »
Re: broken spring
« Reply #21 on: 01 April 2008, 08:11:59 »
The KYB ones appear to be to OEM spec (i.e. progressive rate), cant comment on the other pattern parts
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
Re: broken spring fixed(cheap price too)
« Reply #22 on: 01 April 2008, 19:41:18 »
 :) in G lasgow thefe is a parts wholsaler who supplies the motoer factors/acceserrorie shops any way it would be selfish of me not to share theese prices £18.25+vat = £,21.00
£42.00 a pair
S.R.S IN PORT DUNDAS IS THE PLACE TO GO :y
PS just checked my spelling its awful but i have ust changed the spring in the monsoon ;)
318.25 +vat
dieseldonicely
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
Re: broken spring
« Reply #23 on: 01 April 2008, 21:48:05 »
epc has 18 listed  :o
 13  SPRING,ASSY.,REAR (SET),IDENT   EXC.SPORT             W1000001   -                1    90542360     4
 LQ (EXC.AMBULANCE/HEARSE)
 (EXC.BAD ROAD PACKAGE)
 Note:  EXCEPT AUTOMATIC SELF LEVELLING DEVICE
17  SPRING,ASSY.,REAR (SET),IDENT                         W1000001   - 1    90542361     4
LR (USED WITH AUTOMATIC SELF
     LEVELLING DEVICE)
The faster you go the bigger the grin.  Trade card user.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: broken spring
« Reply #24 on: 01 April 2008, 21:49:41 »
     LEVELLING DEVICE)
Thanks for that Roland.
