Author Topic: Swaping NCDC for 2006  (Read 7278 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 02 April 2012, 21:16:33 »
Looking at removing 2015, Telematics and GID in favor of 2006 and MID on a 3.2 that was factory fitted in 2001, all non Bose.
Whats the chance of a straigth swop with the wiring, or easy mods or just a non starter.
Thanks Chris.   :-\
Re: Swaping NCDC for 2006
« Reply #1 on: 02 April 2012, 21:29:47 »
Two extra wires to run Chris and swap the stalk for the "button" one
zirk
  • Epping Forest
« Reply #2 on: 02 April 2012, 21:34:32 »
Ok, thanks Rob, stalks easy enough, any idea on the 2 extra wires and what there for?
« Reply #3 on: 02 April 2012, 21:39:22 »
Think it might be 3 Chris, they run from the MID to the relacement stalk. TB knows which pins :y
« Reply #4 on: 02 April 2012, 21:54:38 »
2 wires from MID to stalk, and a 3rd from an grounding point behind the dash to the stalk.
I'll dig out pins if thats the line you are going down.
zirk
  • Epping Forest
« Reply #5 on: 02 April 2012, 21:56:14 »
Cheers again Rob, hopefully TB may read and post up, when His not too busy.
« Reply #6 on: 02 April 2012, 21:58:46 »
Keep up ;D
« Reply #7 on: 02 April 2012, 22:00:47 »
Keep up ;D
Chris is getting on a bit mind TB ;D ;D
zirk
  • Epping Forest
« Reply #8 on: 02 April 2012, 22:01:11 »
Ahh, you beat me to it, on the mobile, thanks Jamie would appreciate that.
Chris      :y
« Reply #9 on: 02 April 2012, 22:02:19 »
Chris      :y
Any old excuse :D
zirk
  • Epping Forest
« Reply #10 on: 02 April 2012, 22:06:31 »
Keep up ;D
Fingers work, mobile works, brain works most of time, its the getting it to happen together, multitasking, that lets me down.
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #11 on: 02 April 2012, 22:22:36 »
Any reason why you'd do this swap? Just curious
zirk
  • Epping Forest
« Reply #12 on: 02 April 2012, 23:16:02 »
Yep
zirk
  • Epping Forest
« Reply #13 on: 02 April 2012, 23:26:00 »
Ok, being serious now, where doing a wacky rally to Barcelona for Help the Hero's, at the moment its a toss up between sending  a 3.0 Ex plod manual or a 3.2 Auto, so will be Tom Tom most of way as the NCDC isnit working as it should and does not cover up to date Europe.
Chris   :)
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #14 on: 02 April 2012, 23:59:47 »
Hmmm....   i have a home looking for a telematics.....   ;)
i also have a spare NCDC2013 with working Nav, paired with a working GID ,  but buggered CDC   with the pass code.....
(and a not particluarly good facia...   it likes to jump off..... unless you're careful about how you fit it..    )
if it's of any use in making it all fully functional....  you're welcome to nab it.
« Last Edit: 03 April 2012, 00:05:37 by MaxV6 »
