Author Topic: end float in steering box  (Read 1320 times)
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« on: 02 April 2012, 22:28:33 »
i had the alignment checked and adjusted ( by a wim authorised tire center ) and the techi advised me of some end float in the steering box i watched as he moved the arm up and down it wasnt excessive but you can hear the movement . is the box adjustable for end float should i worry also power steering seems heavy from time to time any ideas . speedo and abs lights are ok ?
2001 MV6 3.2 manual been converted from 2.6 auto
Re: end float in steering box
« Reply #1 on: 02 April 2012, 22:37:05 »
Wonder if adjusting the damper would help that...? :-\ (Torx with lock nut on top of the box)
