Author Topic: gearbox removel  (Read 1841 times)
paintshoptec
  • cheadle, stoke - on -trent
    • 2002 cd v6 saloon
gearbox removel
« on: 03 April 2012, 17:33:20 »
is it easy to remove ar25 box from a 2002 2.6 omega
thanks
Re: gearbox removel
« Reply #1 on: 03 April 2012, 17:38:22 »
Not technically difficult,mostly undoing lots of bolts, but car needs to be raised so box can drop down and then come out.Box is also heavy (around 80kgs iirc) so difficult to do without an extra pair of hands.
paintshoptec
    • 2002 cd v6 saloon
Re: gearbox removel
« Reply #2 on: 03 April 2012, 17:39:29 »
do the cats have to off
Re: gearbox removel
« Reply #3 on: 03 April 2012, 20:28:38 »
Yep afraid so, cats must come off  :(
paintshoptec
    • 2002 cd v6 saloon
Re: gearbox removel
« Reply #4 on: 03 April 2012, 21:09:42 »
got the box but theres a round thing bolted to the fly wheel is that the torque converter
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: gearbox removel
« Reply #5 on: 03 April 2012, 21:11:59 »
Yes thats the torque convertor bolted to the flex plate/drive plate.
paintshoptec
    • 2002 cd v6 saloon
Re: gearbox removel
« Reply #6 on: 03 April 2012, 21:32:48 »
got a other gearbox with coverter ,is it a matter of fitting the torque con back on then refit the box
does anything have to be lined up
Re: gearbox removel
« Reply #7 on: 03 April 2012, 22:40:07 »
Torque convertor should be removed with box - when you fit "new" box ensure TC is in bellhousing and pushed right to back of bell housing.  bolt TC to flywheel through cut out (you need to turn engine by hand to line up each bolt.  HTH
