Author Topic: Sunroof electrical gremlins (or a ghost!)  (Read 5013 times)
Crazycarzowner
« on: 03 April 2012, 18:57:54 »
Got the fright of my life goin to work the other day, just driving along the M62 to do my night shift when all of a sudden WHOOOOSH!!!! I wondered what the hell was goin on, looked around all windows still intact, then looked up, the sunroof was open :o :o :o I hadn't touched it, dial still as was??????????? Its done it again today aswell, I turned on the ignition, started up and within about 2 miles of driving, it opened again!!! (No one told this car it was raining today ;D ;D  ::) ::) )
Anyone any ideas why? or do I have a poltergeist in my car  :'(
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Sunroof electrical gremlins (or a ghost!)
« Reply #1 on: 03 April 2012, 19:09:08 »
Ah yes, the old 'phantom sunroof' again. Common issue, which just occurred recently on mine. There is a guide to cleaning the switch in an attempt to cure it. Hasn't worked for me so I'll have to give it another go.
It is a little scary though when it happens  :-X
« Reply #2 on: 03 April 2012, 19:18:49 »
Replacement PCB needed (black box srewed to motor) ;)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #3 on: 03 April 2012, 19:22:46 »
You think so Rob? Even if it's only an occasional occurrence? Would make sense though  :-\
« Reply #4 on: 03 April 2012, 19:23:29 »
Yep
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5 on: 03 April 2012, 19:26:58 »
Fair enough pal, thanks. Another part for the wish list ........  ::)
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #6 on: 03 April 2012, 19:31:19 »
Have you changed or disconnected the battery recently, if so the sunroof needs re-syncing. Push and hold the button in each position of the roof until it clicks.
Crazycarzowner
« Reply #7 on: 03 April 2012, 20:03:34 »
Can you still get the replacement PCB Rob??? If so do ya know the part no.????
« Reply #8 on: 03 April 2012, 20:47:07 »
Not sold by GM on it`s own Jason, comes with motor
90459138
Crazycarzowner
« Reply #9 on: 03 April 2012, 20:58:06 »
Not cheap then I suppose  :( I might try to clean it first & see if it cures it, if not I'll just pull the plug on it, the air-cons freezing anyway, it just been re-filled, I don't tend to use the s/roof anyway.
« Reply #10 on: 03 April 2012, 21:02:37 »
More trouble than they`re worth
« Reply #11 on: 05 April 2012, 19:27:58 »
Do you want one ::)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #12 on: 05 April 2012, 20:35:55 »
Do you want one ::)
What took you so long  ;D ;D
PM incoming ..........  :D
Perplexer
« Reply #13 on: 23 April 2012, 00:37:26 »
"Phantom roof" problem isn't related to the battery being disconnected and the roof needing to be reset.
See this thread:
http://www.omegaowners.com/forum/index.php?topic=101646.0
