Author Topic: miss fire  (Read 1963 times)
thyagomazz
  • selby, northyorkshire
    • omega b 2.2 cd 16v auto
miss fire
« on: 05 April 2012, 11:50:51 »
Hi.
My 2.2 petrol has developed a huge miss-fire and the idle is below 500 to the point of stalling. The management light is on
I changed the coil pack but still the same
Can u guys help me please?? I love this car and don't want to scrap her
Re: miss fire
« Reply #1 on: 05 April 2012, 11:58:34 »
Hi.
Need to get codes read. When coilpack changed did you check for any oil in the plugwells
thyagomazz
Re: miss fire
« Reply #2 on: 05 April 2012, 21:14:19 »
Yes I did check and was all clear...no oil
I'll get code read asap
Thanks
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: miss fire
« Reply #3 on: 06 April 2012, 15:58:49 »
Hi.
Sounds like a really big girl! :D
Re: miss fire
« Reply #4 on: 07 April 2012, 01:55:19 »
Hi.
I changed the coil pack but still the sameCan u guys help me please?? I love this car and don't want to scrap her
Did you replace this with a Bosch unit, aftermarket ones are no good ime, been there done that.... ::) ::)
thyagomazz
Re: miss fire
« Reply #5 on: 11 April 2012, 19:19:11 »
Robg I got the codes check and It's showing no compression on the second and third cylinders...any clue what to do next??
  • Auckland
    • Mazda MPV
Re: miss fire
« Reply #6 on: 11 April 2012, 19:38:39 »
If it was an A series engine (as used in the original Mini) I would say that no compression on 2 and 3 was caused by a failed head gasket..........
However you don't have an A series and the ECU doesn't have codes for no compression.
What were the codes exactly? (ie what were the four digit numbers)
