Author Topic: Coolant bottle  (Read 4748 times)
Re: Coolant bottle
« Reply #15 on: 07 April 2012, 14:53:44 »
Being an Elite model you will require the one with a "level sensor" inside.
Around £35.00 from stealers,but they don,t come with a new yellow cap...just a black dust cover,so if you want/need a new cap factor in another £5.00.  Simple to replace and makes a world of difference when you next open the bonnet. :y..part # 90500223
Just noticed that about the sensor , so what do the ones without the sensor use for a low coolant level warning apart from steam coming out of the bonnet  :)
Exactly that ;D and the temp gauge.. And of course the weekly checks :y
Re: Coolant bottle
« Reply #16 on: 07 April 2012, 14:57:38 »
Well even though the level sensor is working im still checking the bottle , paranoid or what  ;D
Re: Coolant bottle
« Reply #17 on: 07 April 2012, 16:25:37 »
 ;) Know the feeling though  :)
Re: Coolant bottle
« Reply #18 on: 07 April 2012, 21:23:21 »
Eyeball 1A, during weekly underbonnet inspection.
flyer 0712
Re: Coolant bottle
« Reply #19 on: 07 April 2012, 21:33:10 »
took my header water tank off today   put very strong toilet cleaner..acid type stuff in it...fumes nearly chocked me but when i rinsed it out with loads of water it looked a lot better..but as the previous guy on here stated..the plastic does turn yellowish after a time..having said that mine looks 100%  better...worth doing.. :y
Re: Coolant bottle
« Reply #20 on: 07 April 2012, 22:26:37 »
I put caustic soda in mine and left it for 2 wks , still the same colour ..as its a spare ill try some of that toilet cleaner and see if it makes any difference . Just hope there's not a kaboom  :o  at night in the shed  ;)
Re: Coolant bottle
« Reply #21 on: 12 April 2012, 07:52:04 »
Well another laboratory test on the coolant bottle  :D
Results in progress are in :
Seems a very strong bleach solution say 4-1 ratio has started to work its magic on the brown goo bottle ...significant cleaning and whitening in progress  ??? ;)
